As a follow up to Andrew and Tony’s comments, I couldn’t resist telling the following story.
I was into my 2nd or 3rd year of my apprenticeship when a rather precarious situation developed.
The toolroom heat-treatment plant (a closed off section of the workshop measuring about 8 metres by 6 metres), was equipped with various gas and electric fired cyanide furnaces. A basic gas torch and a brick hearth, along with a bucket of whale oil were there ‘for personal use’.
Quenching of the major throughput was either into a warm water bath for smaller parts, or a very full tank of oil. This tank measured about 150cm deep and was roughly the same diameter. One of the older toolmakers was responsible for all of the once-a-week ‘serious’ heat treatment.
Almost full, the large oil bath became a considerable (flash) point of interest when a large and very hot piece of tool steel (an insert for a compression mould) was being quenched. For scale, the piece (effectively one of several thick-walled cylinders) measured about 150mm diameter and some 400mm long. It was bored out about 45mm diameter through its entire length.
Transferred with some difficulty from a cyanide bath to the hand-operated hoist, the hoist failed (jammed) while the hot insert was half in and half out of the oil. It doesn’t take much imagination to visualise what happened next.
During the initial struggle to free the jammed hoist, the oil began to boil and instantly caught fire. Flames quickly crept across the surface and out to the edge of the tank. Within seconds, flaming oil was dripping onto the floor.
Of greater concern was what was on the other side of the brick wall and thin cement sheeting. It was the powder room known as the drugstore. It supplied measured amounts of rubber, sulphur, and powdered coal to several Banbury mixers and two-roll mills.
Having, for a short while peered through the open door as a not particular welcome spectator, it was time to make my exit. The foreman and a couple of others succeeded in releasing the jammed hoist, quenching the steel, and extinguishing the fire with sand etc. The fire brigade arrived to find the toolroom filled with smoke.
I suspect the other cylinders were subcontracted.
Perhaps that's why I prefer a water quench ![devil devil](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Cheers,
Sam![smile d smile d](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
