Hi all, going back to the original question/comment regarding tempering with lead, yes it can be used for tempering but not a reamer.
It is often used to temper springs, it melts at about 327 deg C and springs are best tempered at around 330 to 340 deg C but your reamer or cutting tools would be tempered at a pale straw 230 deg C.
If you do use lead you need a high temp thermometer and you also need to make sure the lead does not stick–like solder–to your tool, if you have just hardened in oil leave it black, if you have cleaned it up then coat it with powdered chalk mixed with water or meths. VIP IF YOU USE WATER MAKE 100% SURE IT IS DRY BEFORE YOU PUT IT IN THE LEAD *******OTHERWISE SERIOUSE INJURY WILL OCCUR–HEALTH AND SAFETY !!!! ALWAYS USE A FACE MASK GLOVES ETC.
Hardening you need to have the steel above the uper critical point–i.e. in an austenitic condition as Nick says. This varies depending on the steel but as a rough guide silver steel and high carbon steel a dull red [in subdued light] is about 730/750 C quench in oil. For say EN9 you need a bright cherry red about 850 C to harden but it is always best to check in the makers spec sheet for heat treatment.
This is only a “potted” response heat treatment is very involved and to obtain specific results needs very careful treatment for each steel specification.
Best of luck
John.
