Hardened Lathe Bearings Refurbishment
Home Forums General Questions Hardened Lathe Bearings Refurbishment
Viewing 3 posts - 26 through 28 (of 28 total)
  • #648459
    david bennett 8
      @davidbennett8
      You might well be right. I was thinking of the bushes. The area of concern here is one that is often relieved so a loss of hardness where there should be no contact doesn't matter, but you are right to warn care is needed.
      dave8
      david bennett 8
        @davidbennett8
        Well, after considering Howard Lewis' point, I realised I didn't know if large (relatively) lathe spindles were through hardened or case hardened,or something else. After a bit of research, it is still unclear – it could be either. It is quite reasonable to through-harden a hollow spindle of this size. From what I have seen, this is the most likely in a high-end lathe like this, but some form of selective hardening may have been chosen.
        dave8
        #648654
        James Jenkins 1
          @jamesjenkins1
          A huge thanks for all your input on these. I think the take away is to maybe just double check for binding where the two tapers meet, address this issue with a very light stoning if needs be, but then await trials and testing to see if there are actually any serious issues.
          This is what I will do.
          Thanks again,
          James
