I have a Quantum 210 x 400 mm Metric Lathe with a 2.0 mm leadscrew. This lathe is very similar than the Warco 180 lathe.
I recently visited the Warco 180 lathe web page and asked the owner a question or two. One of the questions was about backlash in the Handwheel that moves the saddle left and right. I found the answers on the page of the gadget builder as his lathe is similar as well.
Andy pointed out that I will have better results if I put a handwheel on the leadscrew. I have studied the mod on this page and I wholeheartedly agree that it will be a very good mod / improvement.
My leadscrew ends exactly flush with the end of the lathe bed and my leadscrew is of right hand thread. If I add the handwheel onto the leadscrew directly, it will have to be turned anti clockwise to move the saddle left, and not clockwise as all the other handwheels. I am thinking of adding a small gear onto the leadscrew onto a small axle that I will epoxy into the leadscrew. Onto that gear will run anothe gear that will turn the laedscrew in the opposite direction if I turn the handwheel clockwise, causing the saddle to move left (towards the spindle). This way will cause the handweel's centre to be not on the leadscrew's centre but about 20 mm towards the rear. I can mount it in a movable part that can slide away to disengage when I do screwcutting or anything where I don'st want this handwheel to turn.
Is there perhaps somewhere a mod of similar design? The mod that I have seen on mike's mod page is where the owner has extended his bed a few inches and added a longer leadscrew. The new handwheel have space left on this extended bed to be mounted and can move to disengage. I do not have this space, however I may be able to fix a type of an angle plate to do this mod, mut it will extended more to the right as the first mentioned idea and will still be working the othe way around.
I will appreciate any suggestions or references to other existing mods.
