Hand tools – 5” Kingscale Jinty
Home Forums Help and Assistance! (Offered or Wanted) Hand tools – 5” Kingscale Jinty
  • #642290
    Paul Yeomans 1
      @paulyeomans1
      Hi,
      im very new to this hobby. I’ve recently purchased a Silvercrest Jinty.
      I have no hand tools, spammers, oil can etc.
      is there anywhere where I can purchase such items?
      thanking all in advance.
      Paul
      Paul Yeomans 1
        @paulyeomans1
        Hand tools for 5” gauge loco
        #642294
        DiogenesII
          @diogenesii
          A few to get started with.. ..I'm sure others will have suggestions.
          What vague quarter of the country are you in? – sometimes it's good to be able to discuss options with a supplier over the counter face to face, and there might be someone closer to you..
          Macc Models
          Polly Model Engineering
          GLR Kennions
          AJ Reeves
          Chronos Engineering Supplies
          RDG Tools
          EKP Supplies
          #642297
            Do you know what threads are used on these premade engines? many of the model engineering suppliers tend to sell BA spanners but if Metric is used then you will need to track down small tools to suit in which case some of the mainland European sources may be a better bet.
            GHW
            Knupher
            Edited By JasonB on 23/04/2023 07:51:16
            #642299
            IanT
              @iant
              The Gauge '3' Kingscale loco's I've tested have metric safety valve fittings, so I assume that's what is used throughout.
              IanT
              Edited By IanT on 23/04/2023 08:35:49
              #642300
              Baz
                @baz89810
                Most probably metric threads, chap in the club has a Silvercrest loco and is having trouble with his safety valves, the thread on those is 12mm x 1mm pitch.
                #642312
                Paul Yeomans 1
                  @paulyeomans1
                  So most of the threads are metric.
                  it’s the scanners/sockets I’m looking for.
                  regards
                  paul
                  #642313
                  Paul Yeomans 1
                    @paulyeomans1
                    Oh yes, I live in Australia, so everything has to be electronic.
                    #642319
                    Ady1
                      @ady1
                      xx
                      #642328
                      Bazyle
                        @bazyle
                        Have you found your local Model Engineering club? You are going to need to to have a track to run it unless you build your own and they will be able to help you out, including probably having some members with bits to give/sell you.
