Hi All
Scraping Mild steel.
Over the weekend I decided to try making a small test piece using an offcut of 350 x 75 x 50 hot rolled channel. I milled all the faces and the bottom of the legs first, then got to work scraping it to size. Mild steel is not easy to scrape and I wanted to see how long it would take, in preparation for a bigger project.
So I set to work scraping the 75mm face using Prussian blue on the surface plate to mark the piece.
Some observations:
It is very difficult to scrape in two crossed over directions as you can with cast Iron. The scraping tool digs in. Scoring of the work is a major problem The small 20mm wide curved nose tool used was ground then stoned to a polish. I ended up scraping in fine lines.
After every scrape you have to remove all burrs before cleaning the scraped part and applying the part to the surface plate (having re-spread a thin even transparent coat of bluing), this is the same with cast Iron except the burs are firmly attached… In the end I stoned them off as a file tended to leave them sitting a little proud making false markings .
The first step was to grind the thin edges of the channel parallel to the top. I did this on successively finer sheets of abrasive paper on a flat plate by applying more pressure on one corner you can steer it down and make the top parallel.
I was not able to get a good finish (scratches) however was able to get a reasonable spotting pattern. In the end I decided to finish off by grinding the high spots down with Mylar backed abrasive strip 18mm wide about 600 grade wrapped over the tip of my finger. Using this on the bluing high spots worked quite well.
As the process preceded I was able to get the face flat to within about .0005" high point to low point on the indicator.
Next I used a clean new sheet of 1200 wet and dry paper on a smaller surface plate (Not my good plate) and using this paper first overall then back to spotting with blue got the surface down to .0002" moving the piece under an indicator set on a stand placed on the surface plate.
At this point most of the scrape marks have disappeared being ground away by the second stage.
Then trouble struck!
The same process was applied to the sides. A lot easier having developed a process doing the top. however the top face started to move a curve in the middle .004" high appeared as the work progressed……. No doubt residual stresses. I should have done all three sides at once.
It is fixed now well almost. a thou to go. hopefully one night this week.
Cast Iron is a lot easier to work with but this confirms the steel bearing rail supports for the Epoxy mill can be hand scraped if necessary.
Cheers
John McNamara
Edited By John McNamara on 18/06/2012 16:09:27
