Hammer Handle Supplier??
Home Forums Workshop Tools and Tooling Hammer Handle Supplier??
Viewing 25 posts - 1 through 25 (of 33 total)
  • #20640
    William Chitham
      @williamchitham75949
      William Chitham
        I have a 1lb ball pien hammer in need of a new handle. I've found lots of suppliers of wooden handles on line but none yet (outside the US) that specify the size properly by length and eye size. Mine has a 1"x3/4" oval eye, not too bothered about length. Any suggestions for a supplier?
        Thanks, William.
        #588871
        Dalboy
          @dalboy
          If all else fails have you thought about making your own
          #588889
          roy entwistle
            @royentwistle24699
            I've always had to shave them down to fit the eye of the hammer head.
            Roy
            #588890
            KWIL
              @kwil
              There if you search correctly.
              "Wooden Tool Handles"
              This leads you to Richard Carter Ltd, a Huddersfiel company that makes every sort of wooden handle including club hammer ones!
              #588893
              William Chitham
                Posted by KWIL on 09/03/2022 11:33:15:
                Just found Rich Carter but they only specify by length, I've sent an email enquiry. I found a Faithful that is the right eye size but at 16" seems a bit long to me.
                W.
                #588897
                Former Member
                  @formermember12892
                  #588898
                  Circlip
                    @circlip
                    "But with what shall I saw it dear Bill Dear Bill, wth what shall I saw it Dear Bill, with what?
                    Regards Ian.
                    #588900
                    Craig Brown
                      @craigbrown60096
                      I always shape the handle for a good tight fit in the hammer head.
                      My handles are purchased from a local farm/agricultural supply business, might be worth looking for one local to you
                      #588902
                      Former Member
                        @formermember12892
                        #588903
                        Circlip
                          @circlip
                          But make sure it's made from Hickory dear doc.
                          Regards Ian.
                          #588908
                          Former Member
                            @formermember12892
                            #588909
                            William Chitham
                              What a hilarious lot you are.
                              I could make my own but time is short and ready made handles are inexpensive, probably cheaper than the material would cost.
                              I expect to have to do some fitting but as far as I know you can't "shave up" a handle that is too small.
                              If I "search correctly" I find many suppliers but very few that specify by eye size as well as length. Length isn't an adequate way to specify a handle. Richard Carter for example only quote length and apparently don't sell to consumers anyway.
                              Handles are not cylindrical, a 16" hammer handle with 2" sawn off isn't a 14" hammer handle, it is a 16" handle with the end sawn off.
                              The most important dimensions are of the eye but on consideration I think that I would prefer a handle 12" – 14" long.
                              W.
                              #588911
                              Former Member
                                @formermember12892
                                #588932
                                KWIL
                                  @kwil
                                  Length of handle should not be a problem, just stand closer (or further away) from the impact target.
                                  Unless you have extremely short arms, the required effort should not really vary.
                                  #588936
                                  derek hall 1
                                    @derekhall1
                                    During my apprenticeship in the shipyard many moons ago I was given a new 1lb ball pien hammer and told to cut 2 inches off the length of the shaft as it was deemed "better for close controlled hammering"…
                                    I think the main issue William has is the business end of the wooden shaft. Surely it has to be shaped to size to fit the hammer head before the wedge is knocked into the end grain? Never bought a new wooden handle for a hammer to be honest, when the handle got damaged I bought a new hammer.
                                    My grandfather used to make handles for hammers etc but sadly I dont have his skills in woodwork
                                    Regards to all
                                    Derek
                                    #588939
                                    KWIL
                                      @kwil
                                      Derek,
                                      I think you Apprentice advice was similar to going to the stores for a long wait or left handed screwdriver..wink
                                      #588942
                                      Old School
                                        @oldschool
                                        My father was a working clockmaker and made predominantly skeleton clocks from the simple to orrery,s in batches of 5.
                                        When he died his tools were shared out between us three brothers, as part of my lot I got a ball pien hammer with a short handle it’s turned out to be the go to hammer easy to handle and heavy enough to do what’s needed.
                                        #588946
                                          Regardless of final shaping of the shaft to fit the eye you still want a shaft of the right proportions to suit the weight of the head. Just buying by length could get you a spindly one more suited to an 8oz head or a 2lbs one.
                                          As for suggestions to cut a bit off the end you have to bear in mind that a good shaft will widen towards the end which make sit comfortable to grip and less likely to slip out of the hand. Saw too much off and you loose that thicker end.
                                          Zoro have a range and indicate the size of head the shaft (not handle) will suit, length in proportion to head size. And another supplier of shafts
                                          Edited By JasonB on 09/03/2022 16:22:20
                                          #588948
                                          Former Member
                                            @formermember12892
                                            #588949
                                            William Chitham
                                              Posted by JasonB on 09/03/2022 16:18:45:
                                              Thanks Jason, I've seen the Zoro range but I'm reluctant to buy without seeing the eye dimension. Zoro are particularly hopeless at properly specifying items in my experience. The other link is interesting as they are selling the Richard Carter handles, I have sent an email to them asking for dimensions. This is the only uk supplier I have found so far with the proper info but the the 16" one that would fit is too long for me: FAITHFUL
                                              This one in the states looks just the job, I'm sure I'll find one in the uk eventually: Hammersource
                                              William.
                                              Edited By William Chitham on 09/03/2022 16:39:50
                                              #588962
                                              Bazyle
                                                @bazyle
                                                The Men's Shed get given a lotof tools that need new handles. Nowadays it is cheaper to buy a complete new tool.
                                                As for using hickory, surely that;s only in America and ash is the norm in the UK.
                                                #588973
                                                David Ambrose
                                                  @davidambrose86182
                                                  A long time ago I bought a 2lb ball pein hammer and cut about 3 inches off the shaft. I found it suited me better, and I used the offcut to make a temporary handle for an old power hacksaw blade to cut out an exhaust pipe that had rusted into a fitting on the stern of a PLA launch. I think that I still have both tools – the hammer still has the hole in the shaft for the piece of string in case I dropped it in the Thames.
                                                  #588977
                                                  DiogenesII
                                                    @diogenesii
                                                    Posted by Bazyle on 09/03/2022 18:05:57:
                                                    ..As for using hickory, surely that;s only in America and ash is the norm in the UK…
                                                    …I think every Ash tree in Gloucestershire got cut down before Christmas…
                                                    #588990
                                                    not done it yet
                                                      @notdoneityet
                                                      Mole country stores, or any good ironmonger, should have a selection. Buying from the net, for something like this is just asking for failure.
