hallo from stoke-on-trent
Home Forums Introduce Yourself – New members start here! hallo from stoke-on-trent
  • #584846
    graham wrench 1
      @grahamwrench1
      i have owned a vicroy ex school lathe for some years and never hadto do THREADCUTTINGangry problem is i haveto cut a 1.75 mm thread and my chart goes up in 50,s ie 1.50 2.0 2.5 and so on ,its 3mm feedscrew how do i work out the drive train for this thread ,is there some calculating gadget i can use.
      graham wrench 1
        @grahamwrench1
        #584915
        Chris Evans 6
          @chrisevans6
          Welcome along Graham, I have not got an answer for you but this should bump the question up to the top. I know some online charts may help but someone will be along to advise you.
          #584917
          Harry Wilkes
            @harrywilkes58467
            Welcome to forum from West Mids
            H
            #584923
            Howard Lewis
              @howardlewis46836
              Welcome!
              Don't know the lathe, so unsure if Gearbox or changewheels, so probably not very helpful.
              Can it be configured to cut a 3.5 mm pitch thread?
              If YES, is it possible to change the gear train / gearbox to halve the ratio between Chuck and Leadscrew?
              If NO, it may be possible to use the same technique, of setting up for a pitch that is within capabilities, and then amending the drive train so get a 1.75 mm pitch.
              In theory, my lathe cannot cut coarser than 3 mm, but by substituting a 30T for the normal 40T input to the gearbox, I was able to cut a 4 mm pitch when it was needed.
              If you are cutting a M12, would it be easier to use a Die?
              #584933
              David Caunt
                @davidcaunt67674
                #584936
                Richard –
                  @richard-3
                  #585067
                  graham wrench 1
                    @grahamwrench1
                    hi and thank you for your help .just my luck the gear calculators dont work for my lathe sooo looks like a die [i bet thats expensive for one job ]sad
                    #585119
                    John Hinkley
                      @johnhinkley26699
                      To quote Howard Lewis from a post in July last year on 07/07/2021 12:55:49 in response to a similar query:
                      Cutting a Metric Thread on a machine with a Metric Leadscrew.
                      To cut a 1.5 mm pitch thread on a machine with a 3 mm pitch Leadscrew , the driver could be a 20T driving a 40T on the Leadscrew, with an Idler in between.
                      To cut a 1.75 mm pitch, you would use a 35T driver, Idler, 60T, so that the Leadscrew rotates a little faster than in the previous example.
                      Does that not provide a quick solution?
                      Edited By John Hinkley on 11/02/2022 20:31:39
                      #585134
                      Robert Dodds
                        @robertdodds43397
                        Graham,
                        Does your lathe bear any resemblance to the blue Viceroy that features towards the bottom of lathes.co.uk entry for Viceroy lathes.
                        One of the pictures of that lathe shows a setting plate that includes 1.75 as one of the pitches that can be set on there
                        Regards Bob D
                        #585183
                        graham wrench 1
                          @grahamwrench1
                          hi guys first of all [bob d] nearly but mine has change gears but thanks anyway
                          john/ two of the gears i have not got 35t,60t thanks anyway
                          [that will teach me to drill holes without chcking]surprise
                          #585195
                          noel shelley
                            @noelshelley55608
                            For almost any die made give tracy tools a ring, It may not be that dear if a "standard" and their always very helpful and quick with dispatch. Welcome and Good luck. Noel.
                            #585213
                            Robert Dodds
                              @robertdodds43397
                              Graham,
                              What gears have you got? Is there a 70T among st them?. If so you could be in with a chance but as Noel says check Tracy, Standards are but a few quid!
                              Bob D
                              #585247
                              graham wrench 1
                                @grahamwrench1
                                bob d] gears i have are 16×2,18,20,28,32,38,40,44,48,66,80,100 stud gear 38,and 3mm leadscrew.
                                #585248
                                Brian Wood
                                  @brianwood45127
                                  Hello Graham,
                                  With the gears you have, a combination 28–idler–48 on the leadscrew will  cut a thread of 1.75 mm pitch
                                  Regards Brian
                                  Edited By Brian Wood on 13/02/2022 10:01:58
                                  #585270
                                  Robert Dodds
                                    @robertdodds43397
                                    Brian, Graham,
                                    I went to Church this morning and when I got back home my prayer had been answered. Thanks.
                                    Bob D
                                    #585275
                                    Brian Wood
                                      @brianwood45127
                                      Hello Bob D
                                      Only too happy to help, it all helps in keeping the brain active, although as I am sure you will know, it is not a difficult calculation.
                                      Regards Brian
                                      #585323
                                      Howard Lewis
                                        @howardlewis46836
                                        You just have to calculate the ratio between the Leadscrew thread, and the one that want to cut, and then find a combination of changewheels to give that ratio. This may require one or more compound idlers between the Driving gear and the Driven gear on the Leadscrew
                                        It easier if you want to cut an Imperial thread on a lathe with an Imperial Leadscrew, or Metric on a machine with a Metric Leadscrew.
                                        Cutting A Metric thread on an Imperial machine, or vice versa, is likely to involve a 127T gear for an exact translation. Using a 63T gear may well introduce errors. But in many cases they are small (See Brian's book "Gearing Lathes for Scxrewcutting" for tables giving the errors for ma lot of gear trains )
                                        #585555
                                        graham wrench 1
                                          @grahamwrench1
                                          mr wood ,thank you sir , i really need that book as me and math never get on ,wish id paid more attention at school instead of chasing girls lol……
                                          #585564
                                          Brian Wood
                                            @brianwood45127
                                            Hello Graham,
                                            Thank you, kind of you to say but be aware I wrote the book for a range of lathes having screwcutting gearboxes. But I think it makes what might be a rather dry subject a little more interesting and I hope it gives some insights into the logic behind it all.
                                            The maths in your case is simple enough, Howard has described it well.
                                            Amazon sell the book at affordable cost, the reference is —ISBN 978-1-78500-250-2
                                            Good luck with your excursion into screwcutting, it is rather satisfactory to watch the thread forming as you cut it.
                                            Regards Brian
