Well after a bit of a delay caused by unforseen factors I finally managed to get some time on this example today with reasonable results……
But first a day or two back –
Having bolted the original head back in place the lack of compression and sounds of leaking were apparent. A squirt of fuel showed frothing around the head and the plug seating. There are no gaskets fitted to any joints on this engine. The head was held in soft jaws by the cylinder register and a minimum skim taken across the plug seat. The plug, a ‘Pacy’ was taken apart and the boken insulator repaired with epoxy. (So far no problems with this repair at all). A new copper plug washer was turned and annealed.
The head was then refitted paying real care to the bolting up and the compression improved considerably ( though I still have my doubts over the composite piston’s ability to hold compression as well as one machined from one piece).
The cam was set so that with the timing arm in its retarded postion the spark occured just after TDC and a locking arm made from 1/8 brass rod, one end threaded to fit the timing arm and knurled for grip the other. The intake tube and spray bar fitted was the homemade one that had been proven when using glow fuel.
The coil – totally unmarked so an ‘unknown quantity’ appeared to deliver a good spark from a 6v supply which also showed I guess that the condensor was also functioning correctly. The let down was the petrol – last years lawn mower from the shed kind – spit pop bang – but no run more than two or three seconds and a worn out shoulder however it was felt the parameters were there.
Today however, with new petrol (super unleaded) mixed 4:1 with two stroke oil, another attempt was made. This time the engine showed much more promise and began to fire and run for a few seconds at a time. These short ‘runs’ were sufficient to see that even with the much finer control with the home made needle valve it is incredibly easy to flood this engine. The plug was checked – oily – and the gap checked, something over looked in eagerness. The 30! thou gap then was quickly reset to 10, the plug cleaned and instant success – it fired and ran within an armful of flicks. By manipulating the timing and resetting the needle the revs improved and the engine settled nicely into a reasonably consistant run.
I have no idea of the revs, perhaps 3000 – 4000ish they certainly appeared much lower than anticipated and are not much more than Alan’s engine appears to give. What I was really surprised to find was that the needle in it’s optimum position was open just 1-1/4 turns supporting the comment read that “these type of engines (spark) will run on a mere smell of petrol” (It was some 31/2 turns when using glow fuel)
I have had several runs of three – four minutes (have to think of the neighbours) all on a 13 x 5 wooden prop The engine like Alan’s is still new inside and needs to bed in as yet but is not tight anywhere. The timing arm is not critical as such, but does need to be in ‘just the right place’ to give a consistent run and being able to move it whilst running is definitely a requirement.
As with trying it on glow it does get hot and begins to hunt a little before dying off slowly (newness perhaps) then it does not like starting until it cools somewhat, however I might try some smaller props perhaps 12 and 11 x 5’s to see if the run smooths out at slightly higher rpm
I did take some video and yes I have managed to get it into the computer however does this have to go on You Tube for anyone to see it or am I able to use Picasa as I do with still pics ( I’ve had a good look on Picasa today – it talks of movies and video but simply can’t see how to get the file on there for others to see – anyone know how to do this?
Despite some thoughts I have learnt quite a lot by taking an interest in Alan’s initial posting – it has brought me into contact with others whose opinions have been taken at face value then acted upon to prove right or wrong. By doing that I now feel much more confident in attepting a ‘sparkie’ of my own in the near future which I guess is what its all about.
Regards for now – Ramon
