Home › Forums › I/C Engines › Hallam Engine
Edited By Alan Worland on 27/02/2010 21:19:37
The reason I think this one is home built is that virtually all the flat faces appear to be filed including the piston top.
Edited By Alan Worland on 27/02/2010 21:40:14
Edited By meyrick griffith-jones on 27/02/2010 22:46:51
Edited By meyrick griffith-jones on 27/02/2010 22:50:57
Edited By meyrick griffith-jones on 27/02/2010 23:02:08
Edited By Ramon Wilson on 28/02/2010 15:53:32
Edited By Martin W on 28/02/2010 16:54:12
Edited By meyrick griffith-jones on 28/02/2010 17:45:18
Hi, just a few thoughts. while I was turning up some cylindical squares.
First try reducing the oil ratio down to 10%-12%, it seems to have an excess of oil or fuel dripping out of the exhaust, that could be put down to a bad air to fuel ratio,
Second idea, is that in the early years small manufacturers had to cut costs some how,
Getting the machineist to make there own needles was expensive, so was buying box’s of sewing needles, but there was a big supply of gramaphone needles, unfortunately most makers had different shaped profiles and tapers,So if a hobby model engine maker took one off there own record player, it was a hit an miss affair, The other problem was that 50 years ago, small drills were not the same strength and quality that we have now, and if the home machinist had a worn or badly sharpened drill, if drilled from the needle side of the tube, bell mouthing could occur, As an example put a washer over a morse taper, pull it back, say 20mm and see what the air gap is, then put it in another morse taper, pull it back the same amount, and you will see a much bigger air gap. coupled with a miss matched needle, you now have a hard to tune engine.
So, make a selection of needles of varying tapers, clean up the needle seat, and see how that goes.( MEN has articles on makeing needles and tubes), You need a combination that will allow the coarse needle adjusting screw on your engine to work properly, ie, at least two to three turns of the screw,to get from from low revs to nearly full rev.
I saw an article on making needles, useing the right diameter piano wire, just by fixing one end solid, using pliers or a rod, on the free end and then heating the the section to be tapered,with a gas burner pulling and stretching the wire to get the right taper, then cutting out the section you needed.
Hope this is some help.
John Holloway
My silly question for today: has your battery gone flat?
My silly question for today; has your battery gone flat??
Home › Forums › I/C Engines › Topics
Started by: dangermouse
in: Manual machine tools
Diogenes
Started by: michael howarth 1
in: General Questions
old mart
Started by: Bootlegger Blacky
Bootlegger Blacky
Started by: Robert Graham
in: Electronics in the Workshop
Dave Halford
Started by: Keith Matheson
in: Workshop Tools and Tooling
Vic
Started by: Steve Withnell
in: Drawing Errors and Corrections
Steve Withnell
in: Work In Progress and completed items
Steve Withnell
Started by: David Deaville
David Deaville
Started by: nevillet
Started by: Bill Phinn
in: Workshop Techniques
Julie Ann
Started by: Dalboy
in: Books
Started by: ell81
in: Beginners questions
Clive Foster
Started by: t1krt
Dave Halford
Started by: brucemc777
howardb
Started by: Duff Machinist
Duff Machinist
Started by: ell81
Robert Atkinson 2
Started by: Phil Whitley
in: The Tea Room
Phil Whitley
Started by: Harry Wilkes
Harry Wilkes
Started by: ferroequinologist
ferroequinologist
Started by: JasonB
in: The Tea Room
Nigel Graham 2
Started by: Sonic Escape
Nicholas Farr
Started by: t1krt
in: Introduce Yourself – New members start here!
t1krt
Started by: ell81
Howard Lewis
Started by: jacques maurel
Andrew Tinsley
