Hall Engine
Hall Engine
Home Forums Miscellaneous models Hall Engine
  • #4251
    modeng2000
      @modeng2000
      modeng2000
        @modeng2000
        Leafing through somev old ME mags I came across an article by Clifford Hall in volume 132 number.3304 describing an engine that uses steam power without a boiler. It relies on injected water flashing to steam in an externally heated cylinder.
        I have searched the web but have not found anything. There is a patent number, 923235 which I assume is a British patent. Haven't found the patent yet.
        It seems that Mr. Hall made several engines using this principle. Has anyone else made one?
        David Jupp
          @davidjupp51506
          Patent here **LINK**
          Click on 'Original Documents' on the left side of page to see full details.
          Edited By David Jupp on 20/04/2015 16:02:37
          #187128
          modeng2000
            @modeng2000
            Many thanks for the link David.
          Home Forums Miscellaneous models Topics
