half nuts
half nuts
  • #360780
    Trevor Beamond
      @trevorbeamond52280
      I am looking where I can get a couple of half nuts for the transfer of an old AVO coil winder.
      Half inch diameter, 40 tpi, left hand buttress thread.
      Thank you,
      Trevor
      Trevor Beamond
        @trevorbeamond52280
        #360796
          Welcome, Trevor
          Frankly, the old joke "over there in the corner, next to the rocking-horse manure" springs to mind … but of course, there is no harm in asking.
          My guess is that they will need to be custom made.
          The good news is that people claim great success 'heat-forming' Delrin to make such things.
          For convenient reference; may I assume that the machine is one of these:
          https://archive.org/details/AvoDouglasCoilWindingMachinesManual
          Edited By Michael Gilligan on 05/07/2018 07:59:12
          #360797
          Anonymous
            What model of winder? I think my AVO coil winder is a "Douglas" No. 1. I've never looked before but on close inspection the half nuts on my winder do look to be buttress thread, LH and 40 tpi. You learn something every day!
            Unless you get lucky with a scrap machine I expect you'll have to make them. Depending on the facilities available one could screwcut them, or it may just be easier to make a tap. In my,manual it is explicitly pointed out that the half nuts have a chamfer across the threads so they sit snugly on the driving thread.
            #360874
            Georgineer
              @georgineer
              There's a highly regarded method for making half nuts from delrin/acetal here:
              http://www.denfordata.com/bb/viewtopic.php?f=50&t=3727
              It was originally given on the Home Shop Machinist forum and there is still a 29-page thread discussing it (search for delrin half nuts), but the instructions and pictures were removed from the beginning of it some time ago.
              George
              #360954
              Trevor Beamond
                @trevorbeamond52280
                As I understand it, the "Dougias" No 1 is a hand driven machine. Mine is belt driven with a round belt like a sewing machine. I doubt if it would wind thick wire.. It has a brass plate label 931.. It has a large retrofit counter mounted on a on a piece of RSJ, all very heavy. No motor or drive system came with it.
                I have fitted magnets and reed switches but not built the circuitry to drive electromechanical counters.
                I am most interested in the use of Delrin. I had thought of using Araldite but was worried about it getting stuck to the lead screw. Tracy Tools have a pricey left hand thread tap with normal thread profile which would probably not give sufficient bite.
                Trevor
                #360955
                  Posted by Trevor Beamond on 05/07/2018 22:24:37:
                  The pages at the end of the Manual that I linked may help with identification.
                  Edit: any chance it's this one ?
                  https://archive.org/details/AvoDouglasNo.6CoilWindingMachine
                  Edited By Michael Gilligan on 05/07/2018 22:35:59
                  #360966
                  Sam Stones
                    @samstones42903
                    A word of WARNING.
                    Without even reading through the entire method for forming (pressing) threads into Delrin (polyacetal), which is clearly a smart way; just a word about applying heat to this material.
                    The fumes from over heating are extremely noxious. Get a whiff and you'll never forget it.
                    Good luck with your 1/2 nuts.
                    Sam
                    #360970
                    Speedy Builder5
                      @speedybuilder5
                      Trevor, have you looked at replacing both nut and leadscrew ? And is a LH thread necessary ? If you replace both screw and nut, the choices may open up a bit.
                      BobH
                      #361080
                      Trevor Beamond
                        @trevorbeamond52280
                        I am not capable and do not have the equipment to do an extensive modification. The butress thread is needed as the direction change is done with an over centre system. If I were fit, I might consider running one of the lead screws in the two directions using a stepper motor drive.
                        To change a lead screw would necessitate dismantling the frame and my hammer may not be big enough. I am interested in repairing valve radios and this is a diversion. This week I have been given a fan to repair, I might get it going before winter.smiley
                        I have used the winder to make some pick up coils for a geetah and to rewind some solenoids for slave clocks (30 thousand turns) and to make an inductance for a car low voltage ignition. I initially got it to rewind the mains transformer in an Alba valve radio but changed the transformer instead.
                        Trevor
                        #361082
                        Sam Stones
                          @samstones42903
                          Coincidentally and way off topic Trevor, it might be useful to know that a buttress thread is a highly recommended and much used thread-form for plastic materials’ applications. The reasoning relates to radial creep.
                          By the way, I admire your tenacity with regard to winding those fine wire coils. I recall my electrician father claiming that he was the only one in the workshop with the patience to handle the extremely thin wire. Besides suffering numerous wire breakages, other maintenance chaps who tried came close to nervous breakdowns.
                          Only wish I could help with the half nut problem.
                          Sam
                          #361225
                          Trevor Beamond
                            @trevorbeamond52280
                            I show a photo of the winder, I assume it is No2 but came without any drive. I tried three motors and settled on a 12V motor driven by a Variac and battery charger.
                            The pulley came from a Ford timing belt and has a very nice bearing.
                            I show the rocker with old nuts fitted.
                            But I can't see how to attach a picture obtained from my computer. Where is the paper clip?
                            #361233
                              Posted by Trevor Beamond on 08/07/2018 15:30:27:
                              Here's a Frequently Linked Thread, Trevor: **LINK**
                              https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
                              … It's become a sort of Initiation Ceremony
