The strength of easiflo 2 and the 55% silver cadmium free alternative is identical.
The ductility is very similar – 27% v 24%
Butt joints are the weakest joint design for brazing.As the alloy cools in the joint, it contracts leading to localized "necking". This acts as a "stress raiser" leading to the alloy itself bearing all the stress instead of the alloy carrying the stress from one part of the joint to the other. This is the basis of the phenomenon that in the vast majority of cases the weakest part of a brazed joint is the parent materials. All brazed joints should be designed to operate in shear or torsion – not tension. eg use a strap as per KWIL.
Ensure that the joint is allowed to cool naturally and so reduce any thermal stresses.
Another thought – are you building the crack into the back of the joint by not achieving full penetration of the alloy into the joint.
Make sure the whole of the joint is above the melting point of the alloy. Let the silver solder get its heat from the joint. Do you need a bigger burner fopr a little more heat as per Michael.
Get the part of the joint you want the alloy to flow to hotter than the point at which you feed the alloy.
Ensure the joint gap is maintained between 0.1 and 0.2mm. Too large a gap creates more "necking"
The cadmium free alloy is no more prone to cracking than easi flo2.
Ensure your flux has sufficient life for the heating time. Geneally speaking you can use the same flux for cadmium free and cadmium bearing silver solder. Dependent on the circumstances (temperature and heating time) you may be better off using a longer life flux.
A simple message to all model engineers;
if you stick to the basic principle of the brazing process you will be successful. Everything you do is to promote capillary flow. Get the joint design and materials right, flux them appropiately, heat it correctly. Most problems associated with silver soldering lie behind the torch not in front of it!
Embrace the cadmium free alloys. There are slight differences but there is no need to fear them.
keith
