It's interesting to not Ian's observation on the previous page about his jeweller's vice having the fixed jaw at the front.
This would fit well with piercing and fretsaws normally being used as pull saws.
Also, and I've never worked with precious metals, it would allow the metal shavings to land in the same place, regardless of the moving jaw's position. This would be quite important when sawing gold.
I've often seen jewellers workbenches with a leather sheet suspended below the vice to catch the metal dust for re-use.
In my own workshop, I'm in the slightly odd position of having three power hacksaws, all of which are designed to cut on the push stroke; I understand that most cut on the pull, with the teeth read facing.
The little Kennedy is quite clear in the instructions that it should be set to cut on the forward stroke.
My larger Denbigh very obviously works that way around as the dashpot works on an eccentric cam off the main spindle to provide pressure relief on the return stroke.
Finally the mid sized Manchester Rapidor Minor (9" blade) isn't immediately obvious. On closer inspection, the angle of the blade isn't parallel to the motion of the frame in which it sits. It is lower at the rear, so when it cuts on the forward stroke, the dashpot provides pressure relief on the return stroke.
I understand the same is true of the larger Rapidors as well, It you look at the drawings on Tony's site, one of them even has a badge on the top of the frame showing the teeth set forwards.
Oddly in all cases they cut towards the moving jaw of the vice.
I've seen several larger power hacksaws which cut on the pull stroke, where the dashpot provides both relief and also pumps the frame back up under no sawing lead.
Handsaw wise, I normally use a 12" hacksaw to cut on the push stroke, with junior hacksaw, fret, coping and jewellers/piercing saws cutting on the pull stroke.
Most of my wood saws are traditional British/US, but I do have a genuine Japanese double edge saw, cuts on the pull, with cross cut on one side and rip on the other. ( I probably bought this in the early '80s)
I also favour the cheap Aldi/Lidl saws which also cut on the pull stroke; pull saws allow for a much thinner blade and thus a narrower kerf.
Bill
Edited By peak4 on 12/12/2020 14:41:22
