Don't forget the size of your hole will affect the "fit" just as much as the pin, most off the self reamers are H7 or H8 so your SS will be a sliding fit, you really want it a bit tighter for a dowel pin.
I did have a feeling that proper dowel pins were slightly plus on size.
EDIT, seems I remembered correctly they are plus size as per this maker
Edited By JasonB on 18/11/2018 10:19:11
