Although it seems counter intuitive, when using auto chucks it sometimes helps with the grip factor if you fully insert the drill and then pull it out about 1/2 or 1mm. Because when the chuck grips, it pulls the drill up into the chuck, (by a very small amount), and if the drill bottoms out it prevents this movement which in turn prevents the rotation of the locking mechanism. Just a consideration in conjunction with all the other posts.
Roy
