Posted by Watford on 23/03/2016 21:23:44
Holes of the size shown would seriously effect the balance, so either it was balanced by unusual means OR is out of balance now because of the holes.
Edited By Watford on 23/03/2016 21:25:25
I'm most certainly no expert on this, never having been formally trained as an engineer, (other than with telephone exchanges).
Here's a guess for you; From what I understand, wheels on a surface grinder normally have an oversized hole compared to the spindle size, such that they can be fitted to an arbour and balanced via adjustable weights.
On the other hand, wheels fitted to a small, simple, cheap, double ended bench grinder have holes the same size as the spindle to give a snug fit, and are often lead lined to further help the snug fit.
As such the balance (as opposed to side to side wobble) can't be adjusted, so perhaps it is done at the factory where the wheels are made. One method of this would be to remove a small amount of the material, as per these dimples; perhaps they are not moulded in, but are cut in, to balance the wheel. This would concur with the video that John posted earlier.
