Thanks for your response.
Just to clarify a few points:
Yes, I do know that the wheels are clamped between 2 pieces of paper and that they have to be dressed to make them concentric as the wheel hole is not that accurate and that the spindle on a standard grinder is also not that accurate. Which is why the wheels are mounted on a metal adaptor and then only need a slight dressing of the wheel.
A separate adaptor/arbour is required for each wheel and is located by a taper onto the motor shaft. The parallel shaft would have to be ground for a mating taper. I believe that a short morse taper is used on some grinders.
The Deckel grinder also has a jacking screw arrangement in the wheel adaptor for removing the wheels, which is the type of information I am seeking. (why re-invent the wheel).
Thanks Keith for suggesting Sopko wheel adaptors. **LINK**
Cheers, Paul
