Hi There
You don't necessarily need a 13mm bore.
You could fit standard plastic washers to reduce the bore.
A 60 or 80 grit should do.
Something similar to an A60K5V would do.
Your local engineers' suppliers should be able to get you one and the washers.
regards David
