Thanks for the replies, guys.
I have tried the dremel method with some success. I have also used diamond files which work quite well.
I made a Quorn cutter grinder including the high speed pulley and die holding fixture. My interest is in finding information of how to set up to achieve standard cutting angles.
Examination of smaller size commercial dies reveals a range of cutting angles from hooks to 90degrees.
For taps it is easy just offset the cutting edge and feed the tap radially into the wheel. Grinding the taper with relief is also simple.
It doesn't seem so obvious with a die, particularly a small sized one. How do you grind the taper with relief to the entry to the die?
