Hi Chris,
First, your carbide tips chip easily if you stop a cut with the tool still at the end of the pass and still touching. Carbide is generally quite brittle, so if, say, you are turning down a cylinder and you stop to check the diameter move the tool slightly to the right before stopping the lathe, or better still move the tool to the right to clear the work before stopping.
Carbides often produce a rough finish if you do not take a deep enough cut, the tips producers should/will give details if you can find the makers catalogue. The problem for us amateurs is that often we want to take a small finishing cut to get an accurate size, then we get a rough surface and wonder what the, er, heck.
So the conditions for using carbide are, use the right speed, have the right depth of cut and the right feed rate. All of which will seem a bit fast, a bit deep and a bit quick, and you may not have enough power for the right conditions, either. As a guide there is one tip that is very good for finishing but for 1/2″ diameter in steel the range of speeds is 1800-7000 RPM, bet your lathe doesn’t go that fast!
Fear not, obviously you can use carbide, but they are not necessarily the answer to all metal turners problems. Oh, and just because industry uses carbide and now increasingly ceramics, it does not mean that they are good for you too. Unless of course you have fifteen horse motors fitted, but I think that might not be the case.
HSS on the other hand is, with a few exceptions, the answer to most hobby metal turning. I feel that model engineers opt for carbide because they look at charts giving all sorts of angles and shapes for HSS and think how am I going to be able to grind that lot, well you don’t have to. All a lathe tool needs to cut is a sharp edge. 7-10 degrees of clearance and rake will cut most things, maybe it will be too blunt for some metals and maybe it will wear a bit too quickly in some others but it will almost certainly give a better finish than you are getting at the moment., yes it will work even on brass!
(Mr. moderator take note)
Now to grinding, any old grinder will do, if you change those awful wheels that they come with. Those wheels are for mangling bits of old iron, not your precision tooling. You will need at least one “white” wheel (nothing to do with BNP policy) of perhaps 80- 120 grit. A coarser one as well, would speed up roughing your tools but you can manage with the one. If you can buy a grinder with white wheels fitted it might be safer, as fitting wheels to a grinder is an art in its self and can be a touch risky.(British understatement), most tool shops sell them but unless you know what you are doing get tuition first. Not rocket science but there are pitfalls to be avoided.
The next thing to look at are the work rests, these need to be both rigid and adjustable. Some of the cheapest grinders have, at the best, flimsy work rests. All again is not lost because there are numerous designs for separate rests that would knock spots off the ones on even the most expensive grinders. Downside is that you might well need sharp tools to make one, Catch22??
It’s a bit late for the next grinding course at SMEE, they are fully booked, but there must be a local club to you, where some kind soul can give you hands on tuition. Once you have the basic skills and safety glasses, you can experiment with shapes and angles, to see what works for you and your particular needs. Take all those drawings and angles as a guide, they are remnants of pre-war industry where maximum metal removal is all important, not the case with home use.
It would not be me, if I did not blow the trumpet for Tangential/Diamond shaped tooling, so have a look at the web site for the Eccentric tools found at the top of the home page. There is a video which might open your eyes to the possibilities. Then you can look t this months MEW for plans if you want to make your own. You could also look at the great number of posts about the tools that there have been on this forum.
Hope I have not bored you too much. A whole book, alright a chapter could be written about your requirements but not by me. I am sure someone will come back and say it is all bo**ocks, but works for me. Remember, for every twelve engineers you will get fifteen views, more if they are not feeling lazy.
chris stephens
