Hold the wheel with your finger through the hole, and tap it lightly with a bit of wood, screw driver, hammer handle, or what ever. THERE MUST BE soft paper discs on each side, under the clamping discs, I have noted that one large retailer in NZ sells grinder wheels without the paper washers, any complaints that I have made have been shrugged off. Not the place I would be buying from. The clamping washers should be about 1/3 the wheel diameter, a lot of them are just pressed out of 3 mm steel, and usually a bit on the small size. Ian S C
