Grind stone for drill grinding jig
Home Forums General Questions Grind stone for drill grinding jig
  • #302747
    Rainbows
      @rainbows
      Tried out one of these today. Results were hit and miss but I got two good drills out of it from a short try.
      The worst part was the grindstone as it spun would only contact on a tiny part of the wheel and vibrate everything as it did so.
      With the stone being the one to come with the grinder would a better stone have less axial run out? Even better is there any sort of stone designed to be used on its face?
      Rainbows
        @rainbows
        #302748
        Paul Lousick
          @paullousick59116
          The grinding wheel has to be dressed so that it is perfectly round prior to sharpening tools. A separate grinder, just for sharpening drills and cutters is recommended. See link for dressing with a rotary type tool. Diamond tipped dressing tools are also available.
          Edited By Paul Lousick on 15/06/2017 23:44:32
          #302749
          Rainbows
            @rainbows
            Issue is that instead of using the periphery of the wheel this jig uses the side. I don't think I could do a very good job of dressing it to be perfectly flat.
            #302758
            Thor 🇳🇴
              @thor
              I have a cup like wheel on my bench grinder, so I can dress the wheel both on the periphery and the side.
              Thor
              #302761
              Speedy Builder5
                @speedybuilder5
                As an apprentice, we were taught NEVER to use the side of a grinding wheel !
                BobH
                #302762
                Chris Evans 6
                  @chrisevans6
                  I was also taught not to use the side of the wheel but I suppose most of us do use it lightly on occasion. Like Thor I have a cup wheel mounted on one end of my bench grinder, great for grinding drills and "Splitting the drill point"
                  #302764
                  Tony Pratt 1
                    @tonypratt1
                    Posted by Speedy Builder5 on 16/06/2017 06:40:22:
                    BobH
                    I was also given that advice but in the real world I used the side for all types of grinding where necessary. It's perfectly safe with care i.e. don't ram the cutter/drill into the side of the wheel, take it gently!!!!
                    Tony
                    #302768
                    Antony Powell
                      @antonypowell28169
                      There are several reasons why you don't use the side of a grindstone, I've listed some below….
                      1) They are designed and constructed for face on use only
                      2) it causes imbalance in the stone
                      3) it weakens the structural integrity of the stone
                      4) with side use it can result in stones exploding (I've seen it happen)
                      5) the rest doesn't wrap around the sides
                      6) the guard screen doesn't cover the sides
                      7) Repeatedly using these types of drill sharpener can result in a large groove in the stone effectively cutting off a ring of stone
                      We all do it, We don't think about it when we do, Done within reason it's probably perfectly safe.
                      Health and safety applies even in home workshops (even if not legally enforceable)
                      Wear goggles not glasses, use with care & common sense !!
                      Tony
                      #302770
                      Brian H
                        @brianh50089
                        Maybe it's me but, I don't see why that type of drill grinder cannot be used on the face of the wheel, after all, the face is flat at the point of contact.
                        #302773
                        Jon Gibbs
                          @jongibbs59756
                          Hi Rainbows,
                          I think that one of the key problems with using a jig and a bench grinder is that most grinders have rubber feet allowing them to vibrate independently of the jig. The first job IMHO is therefore to firmly fix the grinder body to the same base as the jig. Then as others have said dress the grindstone face that's being used.
                          The only decent way of doing this for accurate grinding is with a controlled single point diamond IMHO. You can use devilstones or diamond matrix dressers but IME it simply results in a wheel face that's still very uneven and pitted IMHO. Ok for freehand grinding but not much use for precise jig work.
                          I don't see any reason why you can't use the drill grinder jig on the front of the wheel but it would mean getting your other grinding rests, if you have them, out of the way somehow. Harold Halls mag-bases would provide the obvious answer to achieve this though… **LINK**
                          Grinding on the front edge also means your drill cutting edges would need to be horizontal when they are ground. The primary clearance facet would be flat enough in the end but the secondary clearance (assuming a 4-facet drill grind) will end up hollow-ground but under most circumstances that's just fine.
                          HTH
                          Jon
                          #302776
                          Danny M2Z
                            @dannym2z
                            Posted by Antony Powell on 16/06/2017 07:58:07:
                            With a decent grinding rest (I use a Harold Hall design) it is quite practical to use, and dress the side of a grinding disc. With a wiping action, no grooves are worn and the HH rest actually has an optional attachment for using the side of a wheel.
                            My drill sharpener (similar to that shown) has a moving base parallel to the wheel face and works quite well after I added HH's 180° rotation stop.
                            As for safety, always wear goggles/ face mask when using machinery in the workshop.
                            Have fun, stay safe * Danny M *
                            #302782
                            Antony Powell
                              @antonypowell28169
                              but it does still mean ……
                              you are using a stone for a purpose it wasn't designed for.
                              you are still making the stone narrower
                              You are still undermining its structure
                              I advise goggles based upon the fact that sparks always find away around Glasses and masks into the eyes !!
                              But It's you're choice….
                              Tony
                              #302797
                              the artfull-codger
                                @theartfull-codger
                                I've used the side of my grinder for years with my reliance drill grinding jig you can pick them up at autojumbles sometimes,they're really good, what I do is [depending how blunt they are] hand grind on the front as you "should" then they just need a tickle on the reliance, & as for dressing the wheel we allways used a single point diamond when I worked in the glass trade but a better way and cheap as well I just bought a diamond stihl saw or 4" angle grinder blade the cheapo ones not the genuine ones[unless a "bargain "] then I cut them into segments like cutting a cake so they're a couple of inches wide at the periphery & they'r fantastic for dressing & no grooves.I won't add the old H & S stuff we should all know it off by heart now!!
                                #302798
                                Bazyle
                                  @bazyle
                                  +1 for putting both grinder and jig on the same base without rubber feet.
                                  The real reason for workshop warnings about using the side is because halfwits jamming a tool into a clogged wheel heat up a ring and it is thermal stress that breaks the wheel – not a problem with sensible people.
                                  A single diamond dresser is quite fragile so not suitable for use on a bench grinder. They are for taking off a few thou on a rigid T&C machine.
                                  The root of the problem is the wheel mounting unless you are using an ancient jumble sale worn machine. Check your flanges and mounting washers. Don't leave out the plastic or cardboard washer though thinking that direct metal contact will be more accurate – it is there to allow for thermal expansion.
                                  There was a thread on here about 3 years ago describing improvements to these jigs and significantly how to set up and use them. Was that Harold Hall? I recall more than is on his website.
                                  #302799
                                  John Stevenson 1
                                    @johnstevenson1
                                    Side of the wheel or not?
                                    Good question and needs looking at. This all started probably pre war from the wheel manufacturers probably from classic cases in industry but remember back then we had a prolific industry. When I was an apprentice we had offhand grinders with up to 15″ wheels with the big H&S laminated posters of the day hanging up but that never stopped some hairy arsed fitter who had 100 bars in 1″ x 1/2″ that needed a radius on both ends and was on piece work
                                    Result, large undercut in the side of the wheel and bang.
                                    Fast forward to present day and the home workshop and the average weapon of choice is a 6″ grinder with a motor from 300W up to 750W for some of the older classic models. Wheel of choice is usually 6″ x 3/4″
                                    Now our home shop hero is going to [A], die of boredom or [B], burn the grinder out before he’s got his first radius on so no appreciable wear takes place.
                                    In short in a home shop it’s safe as it’s well within limitations.
                                    Ask yourself this, if you replace the wheels with say a 60 degree cup wheel it’s deemed OK to use the face and the side but you are lucky if it’s 1/4″ thick so where is the sense in this.
                                    #302829
                                    Martin Connelly
                                      @martinconnelly55370
                                      I have a CBN wheel with side and face abrasive surfaces. I have a base board with the drill jig on it, the grinder and an xy tee slotted table. You can safely use the side of the CBN wheel as it is a metal substrate not a bonded grit wheel. There was a recent thread on the subject of these CBN wheels.
                                      On my grinder one wheel is the original used for roughing work the other is the replacement CBN wheel, they complement each other well.
                                      Martin C
                                      #302854
                                      Rainbows
                                        @rainbows
                                        Those CBN wheels look lovely, that said I don't have the cash to splash on a grinding wheel like that. Will put it on the wish list.
                                        After finding cup wheel dimensions I found a 150mm wheel has only 10mm of abrasive, as mentioned not too good.
                                        Will try remounting everything more solid and then have a go trying to dress or otherwise shim the wheel and see how that goes.
                                        #302858
                                        RRMBK
                                          @rrmbk
                                          Hi Rainbows. Keep trying with this basic jig. once you get the hang of them they do an acceptable job for most sizes down to about 6mm. the shortness of the drill becomes the problem then. The vee shaped sliding support at the back, in front of the thumbwheel; doesnt need to be as long as it is. I have cut away about half of mine and this enables you to get much shorter drills into the jig.
                                          Two things that I have noticed in using it, that I didn't forsee are — 1 the projection from of the tip at the front is different depending on the drill diameter and for me was smaller than I expected. and 2 — . the need to turn by 180 degrees is important. Harold Hall explains both these very well on his website and in his excellent book on grinding and sharpening tools. He also explains very clearly why these types of jig will not work very effectively on the front of the wheel.
                                          I have made a little angle gauge from a piece of scrap 1/8 plate so I can check the angle of the centre rib on the drill . this should be 130 degrees from the cutting edge and by getting the correct amount of tip projection it sets this angle this angle right . basically use one reference to check the other.
                                          I agree with JS that the issue of side loading the small wheels on our usual home grinders is very low risk and the main issues with wheels bursting goes back to days when very different types of bonding agent were used to make the wheels, compared to the modern speciality adhesives we have today.
                                          That said, using the side of the wheel is not covered by your normal installed protective guard and so a separate additional piece of impact resistant plastic sheet mounted on a simple stand between you and the wheel and drill jig is an easily made and very effective protection measure that costs pennies. This is in addition to your safety goggles or glasses, whichever you choose to use.
                                          Keep practicing with it. once you suss the jig, it becomes a pleasure to have nice easy free cutting drills. It will never match a four facet grind, but the jig is cheap and imho you get good value for what you paid.
                                          #302902
                                          John Horne 2
                                            @johnhorne2
                                            Just as a little sideline to this, a few years back I bought a set of cheap diamond files with 4" blades, they are the most useless and disappointing things I ever bought, but, for dressing a wheel they are excellent, I've even put grooves into a wheel for certain jobs (a spare wheel). Just remember to have your rest nice and close to the wheel or use the file freehand a good way up from the rest.
                                            For drill sharpening I use a little adjustable rest that I made for sharpening lathe tools, this keeps the cutting edge at the right angle, then all it needs is a lick on the side of the wheel to give a tiny bit of clearance, (this is the only time I ever use the side of a wheel).
                                            #302909
                                            Juddy
                                              @juddy
                                              I always find the HSE guidance very good for this type of question, now everyones going to say – health and safety only designed for stopping people working I've been doing it for X years without anything happening etc., but when you actually read the guidance you do find very good advice, with surprising results of what is actually illegal (very little as it happens) and what is just good practise (or not), the key is always taking the correct precautions.
                                              With regards to side grinding they do not recommend it but do recognise that sometimes it is necessary, have a look at section 38 of the guidance for grinding wheels:
                                              John Flack
                                                @johnflack59079
                                                I purchased a fine diamond disc, it happened to be just smaller than my Mini KEF grinder which has an added base to which the Picador drill sharpener is bolted. The disc is a tad short of Gwheel dia leaving both wheels available for"Normal" use , thought was given to washers and the oomph on nut security. The flex is long enough, and the unit portable enough to be used outside the workshop which is my preference. As a modeller my needs may be lightweight to other forum readers
                                                John the bodger and KISS associate member
