Clive, thanks for the link to the Harley site, unfortunately my browser security kicked in and blocked access to the links on the blog as having malicious software embedded, also had a 404 error code on them all.
I did do a bit of web crawling from ideas kicked off by the site though when looking for ultrasonic drivers, and think some of you electronics wizards might enjoy the stuff on this site:
Freely downloadable pdf’s for the transducer driver they built plus a fair bit of other stuff, including ultrasonic drilling using transducers!
Many thanks Les, you’re spot on!
I looked under the dryer enclosure, and there are two more Big valves – Mullard EL34, one bulb has gone a very dark brown and the other white, as if covered in calcium but on the inside, the glass bulb has popped on that one!
Like a dummy, I thought the ‘bulbs’ were just for heating the enclosure where parts are dried – the fan draws hot air from the alloy plate immediately above the valves.
Shows what I know!
I think this thing is likely to be dead and deserving of its last rites, what say ye?
I’ve checked a few ultrasonics on eBay, and looks like 150W is around £150, 100W is around £100, so £1 per Watt.
It was a good cleaner though, and I especially liked the 3x tanks on this old machine which aren’t an option on others!
I could degunk really filthy stuff in fluids such as Horolene in one tank, rinse off, then second rinse in detergent with no need to faff around changing fluid all the time.
Got a few ideas to kick around now anyway.
