Grease Myford Super 7?
Home Forums Website Questions, Comments, and Suggestions Grease Myford Super 7?
  • #436670
    Neil Minter
      @neilminter20597
      I’m in the process of restoring an old super 7.
      When dissembling, I found the clutch assembly and headstock roller bearings were all loaded with grease?
      There was also grease in the ‘apron’ assembly around the pinion gears.
      I can’t find any reference to greasing anything on the Myford, only oiling with the appropriate oils, ie H32, ISO32 or comparable.
      I’ve removed all traces of grease and would just like to confirm only oils should be used before I reassemble?
      Many thanks.
      Neil Minter
        @neilminter20597
        #436682
        john fletcher 1
          @johnfletcher1
          I have the Myford hand book and are unable to find anything about grease, just oil. I used hydraulic fluid which matches the approve specification Esso Nutto 44, mine is a Shell product. Almost any agricultural agent, earth moving equipment dealer, ships chandler has an equivalent. Take along a clean plastic milk container for a litre, should be around £2.50/3 by now. John
          #436683
          Rod Renshaw
            @rodrenshaw28584
            That's always been my understanding . I have owned and used a Super 7 for over 40 years and have always only used oil. The instruction book only mentions oil. I think think the question has been raised on this forum before and the answer from everyone was "Only oil".
            Rod
            #436688
            John Haine
              @johnhaine32865
              Headstock roller bearings? AFAIK only the rear bearing rolls and it's twin ball bearings. And oil is specified not grease.
