Posted by Howard Lewis on 19/03/2021 08:01:32:
Just to take the thread off course a little.
Re The cage in the mine shaft when the haulage rope breaks and the safety brakes fail to operate.
I've been pondering JA's question too, but from a different angle.
I don't know if Davy Lamps depend on gravity or not. I think not, because the fuel is fed through a wick first by capillary action and then by the flame acting as a heat pump. As the lamp is shielded, I think it would burn despite the draught caused by dropping one down the shaft, provided it fell base first. The lamp would be even better protected in a cage.
Takes about 10 seconds to fall to the bottom of a 500 metre deep mine shaft, and the speed on impact will be about 100m/s (220mph). This compares with a car (not mine) capable of 0-60mph in 6 seconds, which accelerates about 4.5 times faster than the falling Davy Lamp, and I can't imagine the car effecting the lamp either?
The deepest coal mine in the UK was about 1400m deep. I don't know what average depth was, but I'd guess iless than 500m. Bet there's someone on the forum who knows.
I vaguely remember a nasty accident in the early 1970s at a South Wales Colliery where a rod in the braking system broke as a cage full of men approached the surface, causing them to smash into the winding gear and fall back down the shaft, I think about 15 dead and 10 seriously injured. Anyone know what the incident was?
It demonstrated accidents are often caused by combinations of circumstances. The rod was 40 years old and a single point of failure. Although designed with a 6x safety factor, bending forces hadn't been taken into account and these were significant each time the brake was operated, eventually causing fatigue cracks. The rod was hidden inside a spring assembly and couldn't be inspected easily. As well as a mechanical braking system, the cage was fitted with electric regenerative braking, which would have reduced the impact considerably. Unfortunately, faced with a run-away, the operator hit the emergency off button (as he was trained to do) and disconnected the entire electrical system, including the regenerative brake. Then there was nothing to slow the cage's fall.
As is often the case, the accident revealed a bunch of other problems. Due to unaffected underground workers trying to find out what was going on the mine's phone system overloaded and broke communication between the rescue party and the surface. In the confusion a number of key managers weren't contacted, which further delayed the response, including not enough ambulances when the injured reached the surface.
Which is a long-winded way of me not answering JA's question. Perhaps I should be a politician…
