Hello Gentlemen,
At the opposite end of the scale to machining graphite, which receives praise as a fine and natural lubricant, may I suggest that the following could serve as a warning for those unprepared as I was.
While looking for a plastic material which offered high creep resistance, I was handed a short length of 50mm dia. glass filled polymer, possibly polyacetal. The glass was in the form of spherical beads less than about 0.1mm in diameter. It machined easily in the lathe with the swarf falling more as a powder than a continuous thread.
Suddenly,
the saddle of my Myford ML7 jammed
Glass beads had found their way past the felt lubricating strip and then between the saddle and the bed. I realised in the nick of time what had happened, and stopped everything rather than try to move the saddle any further.
Clearly, during the machining process, the glass beads had remained intact while the polymer was being shaved away as normal. That part of the machine required a complete strip-down to get rid of all the beads.
Luckily for me and the Myford, the top section of the saddle can be unscrewed and lifted vertically. Even more lucky, the saddle wasn’t traversing under power.
I trust that my experience serves as a warning to ME members and others.
Sam
Edited By Sam Stones on 19/07/2010 06:45:34
