Hi Sheldon
A one or two inch thick slab of granite will flex. If supported on a timber base that is subject to movement due to changes in humidity or temperature.
I have a granite surface plate that is one metre by 800mm by 150mm thick the kind of thickness required for stability under a minimal load being only used for measurement.
Have you thought about casting the bench top in reinforced concrete. There are many videos on the net showing how to do it, it is popular for upmarket kitchen design. **LINK**
As you want to mount a lathe on it you could make it say 6 inches thick and delete the wood planks.
As is well known concrete shrinks on curing and continues to do so for around 30 years, but you will end up re levelling your lathe at least once a year anyway due to ground movement under your buildings foundations.
After the initial cure which is nominally 28 days concrete has achieved full strength. At this point shrinkage slows down to a very small annual amount.
Concrete can be steel trowel floated to a good polish, Or you can buy a few litres of epoxy paint, that will also stop oil or water being absorbed.
DIY concrete is very inexpensive.
BTW most Granite is not completely oil or waterproof.
Edited By John McNamara on 12/06/2014 16:11:48
