Thanx JB those vids were instructive
I noted the typical "smearing finish" on the CI and also the peeling up of the leading edge on the Ali, never seen either of those with HSS
I would not have said CI was a difficult machining mtl (except when it is a raw casting and you have to get through the sand scale). Indeed you dont need lube normally
However those BG tips were about same as my poor experience so far
What do you attribute the difference to? Can the original sharpness have any influence?
Sharpness and carbide are something of a black art it seems. Could BG tips be improved by diamond hone?
Or is it some kind of fake powder being used to make the inserts? Surely whispers in the market will know?
Previously I had ca 20 years doing business in the FE and I got to know the mindset
Lying cheating stealing IP is a national sport. Its tempting to think its directed against the West but that not strictly true IMHO. Its all fiercely competitive out there and they are just as likely to steal of each other as anyone. They will find ways of shaving cents off a product cost even though it degrades that product 50% for the customer
Factories produce for big names under strict QA. The rejects , which are supposed to be binned, find their way out the back door and on to EB BG Aliex etc
Factories making parts have an unsupervised night shift that carries on making these parts to supplement the counterfeit market
Auto parts I had a bad experience with an Isuzu truck. It needed track rod ends. Easy enought to get from local dealer in a branded box – blow me if these parts didnt fail inside 3 months. I couldnt understand it with sealed socket bearings should last 100k miles. I took one apart with a disc saw and to my shock saw that grease had been deliberately left out so just metal on metal
I had numerous totally unexpected failures of obscure parts – anything rubber. A brake vacuum diaphragm – wot?
And garages deliberately swapping out your genuine parts for fakes when you brought our car in for service
The list is endless
Some years ago when DVD R/W recordable discs were all the rage and they were touted as having a lifespan of 10+ years. I was getting disc that were failing inside 3 months. It took me a while trawling the web to find there were millions of faulty DVDs out which had poor quality dye fluid in the make up such that thus would fade quickly over time – not dense enough. and these were big brand names Panasonic Sanyo etc. It was impossible to be sure of a genuine product at the time – draw your own conclusions, saving a few fractions of a cent for extra profit
Anyone remember the scandal of the PRC baby formula milk – adulterating the product with nutritionally inert fillers
Miilions of babies affected
If you want many more examples of greedy dishonest practices PM me for links
So I am very jaundiced and suspicious
Lets face it, buying something on EB is a fraught affair, you have to spend an excessive amount of time examining the bona fides, what they are NOT telling you, how your refund can be compromised specially with Mazon. if the FB<99.5% probably walk away, watch for the dirty tricks, how many times has it be multiple listed masquerading as UK supplier (but its the same big warehouse in Soton) – same photos etc – it could take half an hour.
