Good and the Bad!
Good and the Bad!
Home Forums The Tea Room Good and the Bad!
  • #37255
        I've had a few ups and downs in the last couple of days.
        A big positive is my workshop is finally almost fully operative! I ran up the mini-lathe and the SC4 yesterday, no problems, although a few little things to fiddle with here and there. The bandsaw amazed me by having the blade fitted and ready to cut – I could have sworn it fell off last year and I hadn't refitted it!
        Resin printing is awesome, I have completed a Stug III at 1:35, based on a 1:56 model off Thingiverse. I designed a lot of upgrade parts (hatch, better spare track links, shurzen, jack, fire extinguisher etc.) and from a couple of feet away it stands up comparison with injection moulded kits.
        One issue… don't make the tips of your supports too small, or you will end up having to waste resin running the clean function and peeling a messy layer off the bottom of the print vat with bits of failed print stuck to it
        Last night I printed some mesh covers for the air intakes on it and my Tamiya Panzer III. I designed some with a finer mesh than an example of Thingiverse – 0.2mm with 0.5mm spacing and 0.2mm thick. It's printed beautifully in resin, but very flexible!
        Also, a replacement battery cover for cheap digital calipers – works great. There are several designs on Thingiverse, select a caliper that looks like yours
        The downside, I want to print some speaker surrounds on my Prusa i3 clone. Set it all up with a new nozzle and levelled it nicely.
        First time a dodgy SD card and the print hung after about ten minutes.
        Second time appeared to print OK, but I couldn't get the 'tree-style' support off without damaging it.
        Third attempt and three quarters of the way through, the heater cartridge has gone open circuit.
        In this oppressive heat, I really can't focus enough to replace it this afternoon. It will have to be with an old hot end, but I've ordered a couple of spares, at least they are cheap.
        Other little stories… where have all my small allen keys gone? Where is my razor saw? Why have I got less room in a bigger workshop!
        More news on the way…
        Edited By Neil Wyatt on 22/06/2023 17:17:13
        #649499
        lee webster
          @leewebster72680
          I belong to a local model making club. Last week a young man turned up to see if he could join the club. He designs and hand builds model cars, the photos he showed us was of his latest creation. Imagine the house the Munsters lived in on racing wheels, and very stylised. I showed him some of my resin prints, and he was blown away by the detail. The radiator shell for my 1/10th scale Austin Seven has writing on it 2mm high, and protrudes 1/2mm. Lettering (it is a hand written script style) that has gaps less than half a mil across are sharp and clear. I think it has given him some ideas.
          Thanks for the tip about….. tips. I hadn't given that a thought before. I will now.
          #649513
            So that KX1 should be up and running by the end of the month thendevil
            #649617
              Posted by JasonB on 22/06/2023 18:27:07:
              <Hard Stare>
              #649758
              Howard Lewis
                @howardlewis46836
                You never win'em all!
                My E mail (Outlook ) has been non working since Moday, and my ISL can do nothing about it, so must be down to Microsoft.
                Apparently Virgin users have problems also.
