Glueing acetyl
Glueing acetyl
Home Forums Materials Glueing acetyl
  • #521017
    Roger Hart
      @rogerhart88496
      Trying to make a black terminal for an old AVO without spending any money.
      So far I have a bit of brass with a 2ba thread, a collar and a head 12.25mm dia and 8mm deep. I also have a bit of acetyl with a suitable cavity bored in it.
      The first attempt at sticking brass into acetyl with Gorilla Glue was a failure, it practically fell out.
      Once reasonably secure I plan to turn down the outside, polish up a bit and part off and put AVO back on shelf.
      Any ideas how to glue – or other methods
      Roger Hart
        @rogerhart88496
        #521028
        Brian H
          @brianh50089
          I don't know if this is helpful; depends on cost.
          What is The Best Adhesive for Bonding Acetal?
          #521034
          Grindstone Cowboy
            @grindstonecowboy
            Could you knurl your brass bit, heat it up and melt it into the acetal?
            Rob
            #521069
            Ady1
              @ady1
              pinkgrip
              #521073
              pgk pgk
                @pgkpgk17461
                I'm not familiar with what your trying to do but before dental fillings would actually stick to teeth the answer was to undercut the cavity for retention and make it non-round for antirotation then pack the amalgam in.
                When Epoxy or CA don't work then I sometimes fall back on good ol' copydex or evostick
                pgk
                #521096
                MichaelR
                  @michaelr
                  Having used JB weld for various metal working jobs with good results, they do some adhesives for plastics which may be suitable for your use. Link
                  MichaelR
                  #521118
                  not done it yet
                    @notdoneityet
                    GC has the remedy. Often additionally secured with a screw for further security.
                    #521127
                      Probably worth reading this: **LINK**
                      Paul Lousick
                        @paullousick59116
                        Loctite have some information about a suitable preparation and glue for plastics **LINK**
                        Paul
                      Home Forums Materials Topics
