Posted by Neil Lickfold on 12/04/2018 14:50:25:
A lot of the stunt/aerobatic engines used the long series plug with a head that when the standard plug is fitted is flush. The long plug protrudes the head shape surface, and puts the hole of the glow plug about 1.5 mm or so closer to the piston. As wrong as it sounds, it prevented the very rich fuel setting from putting out the glow plug and made for a more consistent flight. K/B made the long series and the standard plug, with the long being K/B 1L or a K/B 1S, with the S being for standard, not short as far as I remember. There were many brands of glow plugs in the late 70's and early 80's. Now not so many around. Now there are 2 main taper seat type plugs. One has the 60 deg included seat angle, the Turbo plug,from the mid 1990's, with an 8mm body thread with 0.75 pitch. The other is the Nelson taper seat plug,(early 80's) with an 11/32-32 tpi thread body and the seat taper is 110deg included taper. There were also in the 70's the flat seat plugs , from the likes of Super Tigre, that used an M8X0.75 pitch retainer nut for the plug insert to be retained.
If there were a longer reach plug available in the 70s it might suggest that the Jones .605 build notes. which were published from 5th May1978 in ME, did in fact refer to the use of a "long reach"plug. The combustion chamber is dome shaped and has plenty of room for it to protrube. Interestingly, the Chenery Vee-Twin four stroke,of 1983 vintage,also qotes the need for "long reach" Chenery originaly ran the engine with spark ignition,but due to comlaints about it interfering with TV , he changed to a long reach glow plug with no problems. My experience with the the one that I have made is that fitted with the OS F type plugs it would not run continuously. Machining 0.030" off the heads was the answer.
We still have no explanation why Aero plugs just have the type No on the packaging,but model car plugs, as per my OS LC3, have "long reach" on the packet, although they are same length as an OS No 8 aero plug
Keith
