With respect, the Sandvik tool is, nowadays at least, nothing like that. Its quite sophisticated, with a yellow plastic handle, a shouldered boss for the fulcrum, and another sprout to go behind the tip. You put the shouldered boss into a hole in the blade, the ejector sprout goes behind the tip, pull on the handle and out it comes. Fit it the ejector peg on the other side of the tip and it pushes the tip in firmly.
I didn’t get a removal tool with my Glanze tool, and other (Italian) blades which take the same tip as the Glanze don’t give you one either.
Anthony – you don’t need to cut a wider slot. The tool blade is narrower than the tip, so the only points of contact are the very front edges of the tip, and the cutting edge. Coolant, yes of course – most unwise IMO to cut ali with anything without coolant because it picks up like fury and particularly on tungsten with which it has an afinity.
Other thing to check if you are going in deep with a narrow blade and not much clearance is that the blade is truly square to the job. They are not designed to cut wide slots of course – while they are very rigid top to bottom, they are quite flexy side to side, and no one on production is going to cut wide slots unless they HAVE to – time, energy and wastage.
I don’t mean to be unkind, but I’m quite happy to part off 3 and 4″ bar with just a single slot, straight in. But to try to do it without coolant, with all that expansion towards the tool etc – that was unwise. And when I say coolant, I don’t mean a little dob of WD40 (which is NOT an extreme pressure cutting liquid) from an aerosol can – I mean coolant under pressure from a proper pump, though a 2 mm needle directly into the slot – it doesn’t flood everywhere and make a mess, but there is coolant and plenty of it pouring through that slot. ie I mean keeping it cool.
Coolant systems don’t need to be expensive – gravity feed works well from a 5l can. For a long time I used an old mini fuel pump for a recirculating system. But they do have to cool the thing.
Certainly you can get away with a few drops here and there turning externally (but not if you are using heavy cuts and don’t want the job to heat up which leads to inaccurate micrometer readings) but you cannot do the same parting off in deep slots.
As you can imagine, I don’t have much time for suds and WD40 and all the other famed wonder recipes which are so much better than the purpose designed stuff. (soluble or neat) Or so people say.
