I remember having had the same problem with one Int30 holder. One of the surprises when buying some ‘odd lots’ when I stumble over them…
Jist had a look; it was a MK3 sleeve, so is very rarely used only for a couple of large drills.
I solved this problem with the help of a humble angle grinder and some minutes work. The looks are not so pretty, but it works, and it is only for transmitting the torque.
The more complicated way would be to make stepped ‘fingers’. On my machine these are screwed on to the spindle.
Greetings, Hansrudolf
