Giving an aged look to alloy
Home Forums Workshop Techniques Giving an aged look to alloy
  • #595163
    JimmieS
      @jimmies
      I am rebuilding a 1960's BSA Bantam racer and would like to give an aged look, in keeping with the rest of the bike, to the new foot rests and brake pedal made from 6082T6. All thoughts would be very much appreciated.
      Jim
      JimmieS
        @jimmies
        #595177
        ega
          @ega
          Walnut blasting?
          #595179
          Hopper
            @hopper
            Salt water usually does a pretty good job of messing up alloy. Maybe boiling the parts there-in to speed up the process?
            Vinegar will probably etch into it too. Or caustic drain cleaner rubbed on with a rag and watched carefully?
            Bantam Racer? Classic. My first bike was a 150cc D3 Bantam with sprung heel. Snapped I don't know how many front axles jumping it over dirt mounds in the bush down the the back of home. Great little machine. And some of them were tuned up to do phenomenal speeds (Not mine though!),
            Got pics?
            #595181
            Jouke van der Veen
              @joukevanderveen72935
              Why destroying an alu surface by pickling?
              I woud give it a (dull) anodising coating.
              Or start with a light pickle and give it a anodising finish.
              #595189
              MadMike
                @madmike
                As a rebuilder and restorer of British bikes I see a case of over thinking this issue.
                The relevant parts are 6082T6 aluminium. You do not need to do anything at all. Simply make the parts and fit them. The aluminium will oxidise naturally and as a result will go dull and become a natural grey colour. Anodising is best discounted as that will provide an anodic surface to the aluminium which will retain its clean silver appearance for years. Other processes like blasting, rumbling etc will also create a non natural finish which will for a long time look like the cleaning process took place. If you want to speed up the process make the parts and simply leave them outside over winter, otherwise let nature take it course.
                #595190
                Hopper
                  @hopper
                  Rubbing them down with Scotchbrite green pads will dull them down too, if that is all you want.
                  #595459
                  JimmieS
                    @jimmies
                    Many thanks to all for your replies – much appreciated.
                    Jim
                    #595503
                    Chris Evans 6
                      @chrisevans6
                      Try a sample offcut in the dishwasher to see what it does to the finish. Maybe all you need ?
                      #595587
                      Hacksaw
                        @hacksaw
                        What would happen if it was placed in a poly bag filled with oxygen ? Would brass tarnish overnight ?
                        #595654
                        Jouke van der Veen
                          This is about aluminium, not brass. Keeping it in 100% oxygen will not do much. Air is already 20% oxygen.
                          You could also put the aluminium in boiling water which will make a dull surface. But clean it first thoroughly and do not touch it afterwards, otherwise you will get a “nice” stained surface from fingerprints etc. Try a test sample first.
