GHT Drive Belt Material
Home Forums Materials GHT Drive Belt Material
  • #361273
    merlin
      @merlin98989
      Many years ago I made a George H. Thomas Universal Pillar Tool which has stood on the shelf for some years. I now want to use it and have found the 5mm diam plastic belt to be broken and crazed.
      Do members have any advice on a good modern material to use: I expect to have to use a soldering iron to make the join.
      Thanks,
      Ted
      merlin
        @merlin98989
        #361275
        Clive Brown 1
          @clivebrown1
          Look for round polyurethane belting. Widely available, eg try ebay.
          IIRC, mine is 5mm. dia.
          It's worth taking a little trouble over joining. Heat a suitable piece of mild sleel, hold both ends in flat contact with it for a few seconds, then push together firmly. Takes a bit of a knack to get the joint well aligned, but practice make perfect!
          Should add that cutting the ends as square as possible with a sharp blade aids a good join.
          Edited By Clive Brown 1 on 08/07/2018 21:44:59
          #361277
            The material at ebay item 302149867073 is excellent quality, and very reasonably priced.
            … Alternatives are, I'm sure, available.
            merlin
              @merlin98989
              Thanks for the advice
              Ted
              #361287
              Paul Lousick
                @paullousick59116
                O-ring cord is available in different diameters. It is cut to length and the ends are joined together with Loctite 406
                Paul
              Home Forums Materials Topics
