Have a question:
After starting wth HSS, I changed over to a QCTP & carbide toolhiolders, so now I use them the most.
Below is roughtly what I got, and then the question below….
I bought a set of small 10mm carbide toolholders with inserts, I also bought a set of 12mm toolholders with inserts
1-The 10mm set is neautral looking straight and if I place the holders on a flat surcface, all the tips up to thread & part off cutting insert tips measure precicely same height, so I made a toolpost for these only, just insert and the height is always correct. These give a beautifull finish.
2-The 12mm set not all the tips add up to the same height, so I use them on QCTP. They give mixed results.
4-I bought 6mm, 8mm, 10mm, 12mm Iscar boring bars, fitted each in a square machined block to fit QCTP.
-I really like these. I found the 6mm boring bar very handy sometimes.
5- I also have 12mm Kenametal boring bars Left and right type.
6- Bought a separate Part off toolholder with Iscar blade, inserts both sides. These iserts are extremely tough.
and need some pressure to cut. So I grind them sharp with a dremel diamond blade, quick actually, I actually like this, so I grind them now with this tool mounted horizontal on a dremel drill press stand you buy seperately.
-Sharp it part off like a dream. I can also take light cuts left to right without insert coming out.
Heres my question I am not sure about:
From somewhere I understood that although certain toolholders may look negative downward facing, the insert inserted may fit in such a way it actually positively cutting ………Is this correct-?
Edited By Chris Mate on 01/12/2021 20:25:54
Edited By Chris Mate on 01/12/2021 20:27:56
