Posted by Bazyle on 14/05/2015 18:20:49:
Mucky?. Don't use standard ammonia based domestic 'brass cleaners; on clocks as they can cause cracking and corrosion in brass parts a long time later. That's why there are special cleaning products for clocks.
Very true … but do beware: One of the "classic" clock cleaning fluids [Horolene] is, or was, Ammonia-based and caused exactly this problem [Zinc depletion].
Malcolm: Strip it and clean it first
and [to stay on the right side of the enhusiasts]; note that the Gent's version is called Pul-Syn-Etic, not Synchronome; it was a devious bit patent avoidance … I will leave you to find out the difference
