”My original question remains – how can I limit current inrush to charge capacitors etc on startup – I thought VFD might help – but it seems thats not true.”
For a vfd, the initial current is very short and it’s value will vary and only occurs when the vfd is first powered up. It is the current required to charge the internal capacitors. You can also get a vfd with inrush limiting to reduce this.
For a directly connected motor, the starting current is up to 6 times its full load current and is of longer duration. It also occurs every time the motor is started. It is a lot more onerous than a vfd.
If you look at the chart I showed in my earlier post, you see the difference.
Stuart
