Posted by Hopper on 26/12/2022 08:19:13:
It depends…
+1. The answer depends on the purpose the pins and set-screws are put to. Do the items need to be hard, or tough? Does it matter if they're brittle?
The reason different alloys exist is because their properties meet the need in hand. Last pin I made was Brass, not Steel, because it's a Shear Pin, designed to break first in the event of a head-crash.
Most of my pins are made of EN1A-Pb because it's easily machined, and strong enough for most purposes where safety doesn't depend on the pin. It's unsuitable for anything remotely safety critical.
Mild steel is rather soft, so not ideal for bearing surfaces, and, although tough it bends easily. Case hardening creates a thin hard surface on easily machined mild-steel parts, improving their wear resistance. Good for moving parts in clocks, guns, models and other mechanisms. But, because a thin hard layer may not last long in a hard working machine, it's often better to make the part out of a hardenable steel. The disadvantage being that these alloys are more difficult to machine and have to be quenched and tempered properly. The result is inclined to be brittle, especially if tempering is botched.
Although it's often machined, with the exception of the leaded variety, mild-steel is a cheap structural metal rather than an engineering material. Drills, saws, and welds without bother making it good for building ships, tower blocks and car bodies but it's not suitable for bolting wings on aircraft! EN3 is cheaper than EN1A, but it doesn't machine so well. Machines just about OK, but I find it tends to tear and smear making it hard to get a good finish. Leaded EN1A machines extremely well, but the finished part is about 20% weaker than EN3.
The important question is 'does it matter?' If Peter wants to case harden otherwise satisfactory pins just to resist scratching, then I'd stick with EN1A. Apart from availability and cheapness I see no advantage in EN3. And if the pins have important hardness, toughness, and strength requirements, then mild-steel of any type is probably unsuitable.
On the subject of specifications, no-one makes EN1 or EN3 steels. Although extreme resistance to change means many British customers and vendors still call steel by those designations, they've been obsolete since 1972. What you get when "EN3B" is ordered, will be one of several slightly different modern equivalents. Doesn't matter for most purposes, but steel bought for safety critical applications should be ordered more carefully. The correct steel depends on the requirement.
My home workshop requirements aren't demanding and I don't weld, so most of my steel is EN1A-Pb (probably 11SMnPb30 in real money). As only Peter knows what his pins and set-screws are for, he's in danger of getting some duff advice.
Edited By SillyOldDuffer on 26/12/2022 10:24:09
