Thanks Michael G & Mark … that clears it up ..
just in case you are wondering why the interest in bevel gears, I knocked up a simple drive mechanism for my 6" Newtonian binocular telescope which desperately needed some sort of Azimuth drive which didn't have to be accurate but would free up some manual control for adjusting collimation, focus and Altitude.
I used a clamp to fix the drive to the main vertical post of the ram which is required in order that the height of the eyepieces can be adjusted to suit the operator, however the Alt drive has to be disconnected when the ram is raised or the hydraulic ram would tear it to pieces .
Hence the picture of the clamp screw… I had little space to put the motor/gearbox so it had to be fitted vertically, which meant that the drive would need to be connected at 90deg to the motor drive and so a 90deg bevel gear was needed.
I purchased a small bevel gearbox which on arrival I thought might not be man enough, to my surprise it worked without failing, however the gearing could do with being reduced and made a little more robust, so I might have a go myself at making one.
see pics.
