Geared Head Oil
Geared Head Oil
Home Forums Manual machine tools Geared Head Oil
  • #42647
    Anthony Salisbury
      @anthonysalisbury72898
      Does anyone know the best type / weight of oil to use in a gear head lathe?
      Thanks
      Ant
      Anthony Salisbury
        #42655
          Most makers will list a suitable oil in the handbook,  What lathe is it? Its usually a lightweight hydralic type oil.
          If its a far eastern lathe then Warco sell suitable oil
          Jason
          #42673
          Anthony Salisbury
            Warco 1224 Gear Head Lathe but I want a well engineered oil not just a cheap replacment.
            Cheers
            Ant
            #42675
            Dugson
              @dugson
              Light hydraulic oils are best because they do not froth up with the gear action.
              Dugson
              #42688
                From another forum that I didn’t have time too look at yesterday.
                Try these people they do several weights of hydralic oil equal to Shell Tellus in small amounts
                Jason
                #42788
                WALLACE
                  @wallace
                  I had some fully synthetic car gearbox oil left over from a car project – so I drained and filled the headstock on my Harrison L5 with that ! Definetly quieter than the bog standard gear oil used in there previously – and the main bearing runs cooler if ut’s running at high speed for a few hours.. (yes, I know it shouldn’t and I do have a new set of bearings – but not the spare time to change them  . .).
                  I would recomend ‘adding’ a magnet somewhere as it’s very effective at removing metal particles from the oil . .  .
                  WALLACE
                  #42789
                  WALLACE
                    @wallace
                    WALLACE
