Gearbox oil
Gearbox oil
Home Forums Beginners questions Gearbox oil
  • #606437
    Steve Rowbotham
      @steverowbotham77083
      I have a new Warco WM280V lathe which is now due it's first gearbox oil change. The manual specifies Mobilgear 627, which is now obsolete, and the equivalent is Mobilgear 600 XP 100 which I can only find in industrial volumes (25L). I am contemplating purchasing 2L of gearbox oil from Warco, but before I place the order I just wondered if anyone else has been round this buoy before, and if so whether a regular gear oil from Halfords could be recommended.
      Steve Rowbotham
        #606439
          I've just used Warco's "headstock oil" in my 280 for the last 10yrs or so.
          #606440
          Chris Evans 6
            @chrisevans6
            I cant comment on the Warco spec. but most lathes I have used all seem to use an ISO 32 grade hydraulic oil for headstock and gearbox and ISO 68 grade hydraulic oil for the ways.
            #606442
            Journeyman
              @journeyman
              I changed the oil in my similar WM 250 some tim ago. Like yours the manual says to use Mobilgear 627 but this is no longer available so I got some "gear oil" from Halfords reasoning that if it says it′s for gears and it′s going in a gear box, then it will most likely work. The oil in question is "EP 80W90 GL-4" this is marginally less viscous than the recommended oil but should still do the job, especially with the light use my lathe gets.
              Might be something in my Maintenance page that is of interest.
              Edited By Journeyman on 19/07/2022 13:36:34
              #606481
              Thor 🇳🇴
                @thor
                Hi Steve,
                I use "gear oil" from a local supplier, the viscosity may not be correct so I mix in some ISO 68 oil. This has worked well for a decade on my 290 lathe. Just make sure there is enough oil in the gearbox and apron. I know that some use ATF fluid.
                Thor
                Edited By Thor 🇳🇴 on 19/07/2022 18:26:31
                #606487
                noel shelley
                  @noelshelley55608
                  In this context almost any oil is better none ! BUT a good mineral oil, ie SAE10 or 20 hydraulic oil will be fine and as many hydraulic pumps are of the gear type quite suitable ! There is NO need to buy expensive synthetic oils and DO NOT use EP90 gear oil. Any good hydraulics supplier will be able to help and if you take a container may draw from a 205L drum and big savings ! Good Luck, Noel.
                  #606491
                  Robert Atkinson 2
                    @robertatkinson2
                    As Noel has said, don't use any EP oil! Don't use EP oil in any application that uses copper or copper alloy components. The sulphur and other additives in most EP oils (there are some modern exceptions) can damage them.
                    The specified Mobilgear 627 is an iso 100 grade oil so Nuto 32 is a bit thin.
                    My first stop for odd oils is Morris lubricants.
                    https://www.morrislubricantsonline.co.uk/
                    Drop them an email. We should support these british companies that aupport niche users. They sell steam oil
                    #606498
                    Journeyman
                      @journeyman
                      I don't think an EP oil will be a problem with these gearboxes. They are crude low tech cast iron and steel things.
                      I can't remember seeing any brass or copper in there. They rotate very slowly at very low power so not mission critical. I think you could put golden syrup in it and have no problem.
                      Robert Atkinson 2
                        @robertatkinson2
                        Are you sure there are no bushes?
                        Personally I would not take the risk. Even 100 weight engine oil would be a better choice and cheaper too.
                        Robert G8RPI.
                        #606508
                        Pete Rimmer
                          @peterimmer30576
                          What's the problem with EP90? not that I use it I'm just wondering why it's such a DO NOT?
                          #606509
                          john halfpenny
                            @johnhalfpenny52803
                            Some EP90s have additives that are said to attack yellow metals. There is no definitive list, and perhaps modern formulations are ok. Hence the advice to avoid, just in case.
                            #606528
                            Hopper
                              @hopper
                              GL4 spec EP oils are usually compatible with yellow metals as are some of the modern GL5 formulas. Usually it will say on the container if its compatable. I hate the smell of that stuff though.
                              And you dont really need EP additives for a 1hp lathe transmission vs a 100+ hp automotive tranny.
                              Edited By Hopper on 19/07/2022 22:53:13
                              #606529
                              noel shelley
                                @noelshelley55608
                                Once upon a time there was OIL ! It was a lubricant ! Now there is an oil for every job. A friend bought a vehicle from a less than reputable dealer – 6 months later the AA recovered said machine it was going to cost £3000 to f ix due to the wrong engine oil poisoning the CAT. ! Some things can use almost any oil, others need a very specific oil – you just have to judge for your self or seek advice ! A simple gearbox, lathe , old motor cycle Etc would be quite happy on a SAE30 engine oil, if it's good enough for an engine that may run at 5000rpm, crank pistons timing gear Etc then the lathe will be fine ! EP 90 is best kept for high load spiral bevels Etc. Noel
                                #606533
                                Steve Rowbotham
                                  Thanks as ever for your informative responses, I have managed to establish that the recommended oil is Astra 68 slideway oil – the manufacturer being Morris lubricants! It may have been easier to just buy from Warco, or plump for an engine or hydraulic oil, but at least I now know what spec. the manufacturer intended (and it's not golden syrup). Good to hear from you Thor, you will be pleased to know the Stuart Oscillator is now complete and running merrily on compressed air, and I have today unboxed a Stuart 10V set of castings – a bit more daunting than the oscillator so expect more requests for advice!
                                  #606535
                                  duncan webster 1
                                    @duncanwebster1
                                    If you're in the northwest then Caldo oils sell most grades in small quantities. Some oils advertised as slideway lubricants contain a waxy substance which if used in a gearbox will eventually bung up the sight glass. Not good
                                    #606546
                                    Neil Lickfold
                                      @neillickfold44316
                                      I use ATF oil. Its used in the box for Hardinge lathes. It has additive for acid and alkaline . Does not cause issues with mixed alloys like bronze or aluminum or steel. I don't own Warco machines . I buy the cheapest ATF (auto transmission fluid) I can buy. Its great stuff. Some smell really bad or strong, so I don't get those ones.
                                      #606588
                                      Nick Wheeler
                                        @nickwheeler
                                        Posted by john halfpenny on 19/07/2022 21:17:50:
                                        It also smells awful.
                                        I use Dextron3 Automatic Transmission Fluid in and on my WM250 because it's basically just the thin hydraulic oil with some extra dye. And I had about 3litres of it going spare.
