Gear wheels
Gear wheels
Home Forums General Questions Gear wheels
  • #654571
    Milly S
      @millys
      Hi I’m after 2 gear wheels for Chipmaster
      24tooth & 66tooth tried to put these on
      wanted adds with no luck
      maybe someone can advise please
      cheers
      steve
      Milly S
        @millys
        Chipmaster lathe
        #654575
        Nigel Graham 2
          @nigelgraham2
          Are these change-wheels or internal ones? For the former, try a second-hand dealer like Home & Workshop Machinery.
          Alternatively, if you know the pressure-angle, a transmission-parts stockist like HPC, Bearing Boys, etc. . These firms sell stock gears that need their pilot bores and perhaps other details machining to suit the application; though now of course some might only stock metric-size wheels. Also most gears now are of 20º PA: they will mesh with 14º 30' wheels but not properly, in time harming both.
          #654589
          Howard Lewis
            @howardlewis46836
            It is posible that gears for other Colchester vlathes would fit.
            If you can quote the DP (Assumed to be DP being a British machine) and other dimensions, Thicknessm bire etc ) it might be possible to find ones for another machine that could fit, or be modified by machining, (Thinning, opening up/ boring and bushing ) to suit your machine.
            What is some one else's surplus material might be your raw material for the gears that you require!
            #654596
            DC31k
              @dc31k
              Posted by Howard Lewis on 31/07/2023 17:45:24:
              His previous question on the same subject was on 25/07/23 (https://www.model-engineer.co.uk/forums/postings.asp?th=187461). The details you ask for are in that thread, posted 26/07/23.
              #654608
              Milly S
                @millys
                Hi Howard my Chipmaster is the continental
                ive only had it a few weeks trying to collect
                everything that goes with it the gears that came
                with 1 of them had a broken tooth
                with advice I received from forum members
                i decided to repair it myself by welding
                & filing it turned out perfect
                im collecting a set of change gears
                as I’ve started single point screw
                cutting mainly to replace parts for
                my sons garage
                thanks
                steve
