Gear resources
Gear resources
Home Forums Suggested Online Resources Gear resources
  • #52997
    Terryd
      @terryd72465
      Here is an interesting resource from the Boston Gear company.  It has a load of useful data on gears as well as a very good explanation of many gear technology terms and concepts.
      The link will take you to chapter 1 of 5 pdf documents.  The easiest way I have found to get to the other chapters is to simply change the chapter number in the url.
      Terry
      Terryd
        @terryd72465
        #71706
        John McNamara
          @johnmcnamara74883
          Hi All
          I am looking for a free gear and timing sprocket profile generator, to enable me to generate an accurate profile of the part, then extrude it and edit it in CAD. ideally one with DXF output.
          Does anyone know of one?
          Cheers
          John McNamara
            @johnmcnamara74883
            Hi All
            I am looking for a free gear and timing sprocket profile generator, that will generate the profile of a gear then export it as a DXF file I can work on using CAD.
            Cheers
