Gear hobbing in the lathe
Home Forums Workshop Techniques Gear hobbing in the lathe
  • #248344
    Baldric
      @baldric
      I have seen this on another website **LINK** and thought it needed a wider audience. I was thinking I may build a hobbing machine, possibly the one being serialised in MEW, but this may be an easier option. Only thing is need to remove the rack to disable the traverse, I am sure there would be other options such as adding a separate take off from the lead-screw, I guess the feed is also manual.
      ​What do others think?
      Baldric.
      Baldric
        @baldric
        #248364
        John Stevenson 1
          @johnstevenson1
          Very interesting except for one thing in the comments. Couple of people mentioned the Jose Rodregious DVD on gear cutting.
          Do not waste your time and money on this one for many reasons. One he uses the wrong value for Pi, 3.416 ?? So all his calculations are wrong. The filming is all out of focus so a close up shows nothing and he’s using a machine made out of wood and licorace so the end result is about as good as a worn out jubliee clip.
          Don’t waste your money, if you want videos, go on You Tube and search for a user called Hobbynut.
          Far better videos and for free
          #248422
          I.M. OUTAHERE
            @i-m-outahere
            Posted by John Stevenson on 28/07/2016 15:11:29:
            Do not waste your time and money on this for many reasons . One he uses the wrong vaue for Pi, 3.416 ?? So all his caculations are wrong.
            I agree , he even gives you a photo copy of his formula that is also incorrect !
            How do i know this ? embarrassed
            The funny thing is when he free hobs the gear he has to set up the dodgy dividing head and gash the gear blank anyhow , i would have just used a normal gear cutter and not worried with making the hob .
            You can buy asian made cutters that work just fine cheaply enough .
            Must check out the Hobby nut channel , sounds interesting !
            #248453
            I.M. OUTAHERE
              @i-m-outahere
              Damned if i can find the hobbynut channel or user ?
              #248460
              Bazyle
                @bazyle
                If you do a search you get another thread on this forum with a link from JS – and that never worked either devil
                #248470
                John Stevenson 1
                  @johnstevenson1
                  Yes sorry lads, quick look and I can't find it. I'll look later tonight but if like me, he lost his primary Google account it wipes all your Youtube video's out unless you re-upload them.
                  #248476
                  Ajohnw
                    @ajohnw51620
                    If some one wants to hob gears at least the lathe mod looks interesting.
                    I've more or less concluded that conventional cutters are a simpler option. A few cutters as needed doesn't have to break the bank. In fact sets in some small sizes need not be that expensive.
                    If for instance I want to cut mod or dp worms on my lathe I will have to cut some gears. 2 of them. I just need 1 cutter for these and for the use the cutter will get RDG stuff will be fine. In fact a silver steel one would do.
                    There are several options on things like clocks but I suppose these could be hobbed as well.
                    John Stevenson 1
                      @johnstevenson1
                      But try buying a cutter for a special gear, that's where hobbing comes into account.
                      Three gears, all with different number of teeth but all cut on the same blank.
                      Only one of those could be cut with a gear cutter.
                      #248512
                      Bazyle
                        @bazyle
                        Posted by John Stevenson on 29/07/2016 09:59:43:
                        That's bad news – all sorts of good stuff could disappear if someone dies or has a computer wobbly. Bit like losing stuff off a forum or when picture hosting sites time out.
                        #248517
                        Paul Relf-Davies
                          @paulrelf-davies37806
                          https://www.youtube.com/user/Hobbynut
                          I doesn't help that the link contains 'Hobbynut', but the name on screen is: OldManShorty
                          Scratch that.. No ME-elated videos….sorry ….
                          P.
                          Edited By Paul Davies on 29/07/2016 13:31:51
