Gear hobber (mechanical)
Home Forums General Questions Gear hobber (mechanical)
Viewing 8 posts - 76 through 83 (of 83 total)
  • #262865
    Chris Robinson 2
      @chrisrobinson2
      Message for the moderator :Please remove my e-mail address from my previous post as advised
      Thanks, Chris.
      Gustav Thiesen
        @gustavthiesen53240
        To Chris Robinson:
        Thank you very much für your post. I'm very interested in the basics of your differential add-on. So I would be pleased to receive your informations. Perhaps you can give me some tips of the design of the add-on too.
        #262898
        Bazyle
          @bazyle
          For the record, from Neil’s spreadsheet index
          “Using the Jacobs Gear Hobbing Machine to Cut Helical Gears Part 1”
          MEW 2010 November vol 169 page 36 by Chris Robinson.
          Not sure what it covered as I can’t find this issue.
          #262902
          Chris Robinson 2
            @chrisrobinson2
            Bazyl, This article, which I wrote was published in MEW in 4 parts. No.169 Nov 2010 pp36-41, No170 Winter 2010 pp 32-35, No172 Jan 2011 pp 44-48. It covered modifications to the Jacobs hobber to cut helical gears. I wrote a further article covering the fitting a differential to the index train, cutting worm gears using plunge feed, cutting worm gears using ACME taps as hobs with tangential feed and more but MEW declined to publish.
            If you message me your e-mail address I can send this to you.
            #263009
            Tendor
              @tendor
              This diagram of the kinematics of a commercial universal hobbing machine (DEMAK) might be of interest.
              It might not be obvious, but to cater for hob lead and helical gears, the hob axis can be tilted about the axis of gear pair H-I.
              #263025
              Marischal Ellis
                @marischalellis28661
                Hi All
                Do you use Google translate to understand a thread? . Seems to work for me the few times I have tried it. Just a thought for Gustav.
                Best wishes to all.
                M
                #263026
                  Posted by Rodney Entwistle on 26/10/2016 06:15:02:
                  Thanks, Rodney
                  That's very helpful yes
                  Duncan Munro
                    @duncanmunro42894
                    This diagram of the kinematics of a commercial universal hobbing machine (DEMAK) might be of interest. […]
                    Wow! That's some machine smiley Thanks for posting.
