Gear hobber (mechanical)
Home Forums General Questions Gear hobber (mechanical)
Viewing 25 posts - 1 through 25 (of 83 total)
  • #226322
    Gustav Thiesen
      @gustavthiesen53240
      I'm looking for information about the gear hobber of college engineering.My special interest is pointed to the production of prime number gears, for example the 127 teeth gear. Now i want to know, whether the kit or the plans form college engineering will give enough information about the construction of the differential gear addition to the jacobs gear hobber.
      My email request to college engineering to answer this question was not responded until know.
      Is there any member of the forum to give me more information?
      Gustav Thiesen
        @gustavthiesen53240
        #226341
        Bazyle
          @bazyle
          I assume you are aware of the modified version in the USA by Gary Martin Models. maybe they can supply information.
          I'm not aware of the use of a differential in these machines so interested to hear what you currently know about it.
          #226342
          John Haine
            @johnhaine32865
            Do you particularly want to hob gears, of just make prime number gears? These days, I would have thought that a stepper driven dividing head, using for example Steve Ward's controller, would be much easier.
            http://www.worldofward.com/rotarycontroller/overview/
            #226350
            KWIL
              @kwil
              Gustav,
              You will find Mike Haughton (MEW Author) has a lot of experience on Jacobs Hobber, if you PM me with your email I will forward your queries.
              #226352
              Another JohnS
                @anotherjohns
                FYI.
                I've looked at the Martin Models castings (on line) for their gear hobber.
                But – a Brit (Andy Pugh) has done interesting things gear hobbing with LinuxCNC (old name of software: EMC). Go to Youtube, and look for "Andy Pugh Gear Hobbing" and see what comes up.
                (This might be much easier/quicker to build than a mechanical hobber, but I *do* like the Martin Models version…)
                John.
                #226381
                Gustav Thiesen
                  @gustavthiesen53240
                  Many thanks for the posts. I hope that Mike Haughton will help with information. I'm more interested in the old- fashioned way with a gear train, i think that I'm to old for the electronical way of construction.
                  #226389
                  Ajohnw
                    @ajohnw51620
                    I would have thought the simplest and easiest way to make a 127 and others would be to use a dividing head with yet another worm and wheel driving the worm on it as per the G Thomas design of old.
                    In some ways it's better than differential dividing as the flank errors can be worked out and then averaged rather than getting as close as possible with summed fractions.
                    Must add though that some people desire things like 127T gears for conversion sets to allow metric to be cut on imperial machines. There is no need for them as approximations can be derived which exceed the accuracy that's likely to be achieved anyway even with it.
                    Stepper generally have a step accuracy of 5% by the way. I suppose that the usual argument can be made that this is reduced by the ratio of the worm and wheel they drive but I reckon dividing plates are better.
                    Edited By Ajohnw on 21/02/2016 23:10:04
                    #226392
                    Bazyle
                      @bazyle
                      "In some ways it's better than differential dividing as the flank errors can be worked out and then averaged rather than getting as close as possible with summed fractions."
                      I think differential indexing is exact but compound indexing uses the sum of fractions which cannot therefore create prime divisions.
                      #226422
                      Ajohnw
                        @ajohnw51620
                        laughYou are correct Bazyle. No matter people probably understood anyway. I should go to bed rather than looking to see what's going on here.
                        In terms of change wheels people have generated very precise approximation for metric on imperial but I can't recollect seeing any for imperial on metric.
                          Posted by Ajohnw on 21/02/2016 23:07:19:
                          I'm not arguing, John … but, on a typical 200 step/rev motor, that's one part in 4,000 [which probably compares favourably with much of what we do].
                          Phil P
                            @philp
                            Gustav
                            Just be aware that if you do decide to build a gear hobbing machine, the small hobs are not that easy to find these days.
                            I have a good selection for my own Mikron 112 hobber, but it took a good few years to obtain them and I still look every day on the off chance something I need turns up.
                            Phil.
                            #226469
                            Ajohnw
                              @ajohnw51620
                              Posted by Michael Gilligan on 22/02/2016 11:38:33:
                              I looked at in terms of angular error Michael. Initially because when they first appeared I thought what a simple dividing device used all on it's own with some form of zero shift clamp. I'd need to check again but think it's +/- 5%. There are better, a few cropped up on homeworkshop but went very quickly. Less steps and off a cnc machine if I remember correctly.
                              The Thomas design uses a 60T and 40T worm and wheel. That's 1 part in 2,400. Can't remember how many divisions on the dial but rather than make it on it, which is possible ones with 100 are about giving 1 part in 240,000. Good enough to make a sizeable gear but fiddly. It's a case of advancing so many divisions and periodically minimising the error by altering that slightly.
                              I did some sums before building one and then bought a Dore Westbury which came with the Westbury dividing head. I think the dial I had found had either 200 or 150 divisions but his design was ok. I do intend to fit a larger worm wheel to the Westbury one when and if I need to. Bigger plates too but for my limited use of it the items that came have been fine. Thomas describes how to make the plates in his book but a local supplier had a lot made and sold them at rather low cost. It wasn't worth even buying the blanks.
                              Edited By Ajohnw on 22/02/2016 15:18:29
                              #226471
                                Posted by Ajohnw on 22/02/2016 15:16:18:
                                Have a look at information from companies like Oriental Motor, & remember that the quoted error is [of course] non-cumulative.
                                Micro-Stepping does not help much, because it the intermediate micro-steps are not true detents … but motors are available with 800 real steps/rev.
                                MyrtleLake
                                  @myrtlelake
                                  127 tooth, 1 MOD.
                                  The mechanical hobbing machine looks fun.  I agree, though—won't you then have to make the hobs?  So that leads you into making the Eureka relieving tool.  How far do you want to take this?
                                  Edited By MyrtleLake on 22/02/2016 17:37:03
                                  #226484
                                  Ajohnw
                                    @ajohnw51620
                                    If I have done my sums correctly a 200 step driving a 90T worm, 5% is equal to around +/- 0.001" error per inch of radius.
                                    Cranky old calculator. VPAM drives me up the wall but I'm sure the calc acts up now and again, surprise I even liked reverse polish, even less key strokes.
                                    Loosely speaking 800 steps would 1/4 that if it's still 5%. That's more like it.
                                    Alan Vos
                                      @alanvos39612
                                      Posted by Ajohnw on 22/02/2016 10:05:29:
                                      Try this http://littlemachineshop.com/reference/change_gears.php. It works both ways. Also for BA (as metric pitch). How close you can get is affected by which prime number gears you can get for your lathe.
                                      (First post here for some time, so if the formatting is a mess…….)
                                      #226488
                                      MyrtleLake
                                        @myrtlelake
                                        The Sherline rotary table…
                                        400 steps per handle revolution. Worm and gear makes 72 turns for one full rotation of the table. So 28,800 steps per 360 degrees. That equates to 80 steps per degree, which in turn equates to 0.75 minutes per step. Final controller, electronic position is accurate to +/- 0.5 step.
                                        "This turns out to be a very small amount because the sine of this angle is only 0.0001091. This will amount to 0.109 mm per 1 meter when compared to a flat plane. This is just 0.0055 mm at the edge of the table"
                                        http://www.sherline.com/8700inst.pdf
                                        Good enough for me!
                                        #226492
                                        John Stevenson 1
                                          @johnstevenson1
                                          So what happens to all the calculations if your plates are generated on a stepper driven CNC ?
                                          #226496
                                          Ajohnw
                                            @ajohnw51620
                                            Proper CNC machine I would hope John. The few I have bothered to look at in detail – older used one seem to use low step count motors. I assume like the far more accurate ones I mentioned. So far I have resisted buying one.
                                            As to sin and pdf. I used tan but the answer is virtually the same anyway. Really a different type of trig should be uses as sin and tan don't equate to arcs.
                                            360/ (90*200) = 0.02 degrees, 5% of that is 0.001 degrees. Sin of that 0.0009999999 tan 0.001000. So both come out at one thou per inch of rad. The assumption that 800 steps would 1/4 this is fairly valid if the error is the same. 400 would halve it. A 72T worm would make it worse.
                                            That sort of error with 200 pulses is a bit debatable on larger gears such as 127T. As Michael pointed out micro stepping is more iffy and steps will be made anyway. Where high accuracy is needed on things like astro telescopes the answer is generally a lot of gearing and closed loop feedback – the star is tracked and the steps corrected as a result. The other option used is to fit an encoder and drive according to that – not step counts. Some do the obvious then and use an ordinary motor to drive instead.
                                            One aspect of cnc is interesting. When I visited chester m/c tools the sales man pointed out that numbers come out of their simple digital scales and he wondered why some one hadn't done a machine that used these.
                                            surpriseIt could be done with +/- 1u scales too. The real ones of course if they exist.
                                            Edited By Ajohnw on 22/02/2016 20:31:51
                                            #226508
                                            Ajohnw
                                              @ajohnw51620
                                              Bedtime but this site explains the problem rather well –
                                              I often hear, exaggerated by me of course of some set up with a lead screw being micro stepped at 1/10,000 of a step so the system is accurate to blah blah when it wont be.
                                              There are some rotary encoders about that offer a high power of 2 resolution as well but it's best to look at the claimed accuracy rather than the headline figure.
                                                Gustav,
                                                You may be pleasantly surprised [as was I] to find that lathes.co.uk has this useful page about the Jacobs hobber.
                                                Gustav Thiesen
                                                  @gustavthiesen53240
                                                  Many thanks for this information, but I'm visiting lathes.co.uk for a couple of years. This is a very good side and i know the side concerning the Jacobs machine. There is only a picture of the "differential addon", but no further information.
                                                  Some members of the forum have answered to my first question misunderstanding the term "differential addon".They thought that it was pointing to a special form of dividing or dividing head. In this case the term is better compared with the differential bearing of a car equipped with some bevel gears in order to transmit different speeds. All I want to know is, wether the kit or the plans of college engineering will give sufficient information to built and to use this differential addon in order to hob prime number gears. This differential addon is a later invention, the first plans from 1976 didn't deal with the production of prime number gears.
                                                  #226555
                                                    For the benefit of those who may be better able to advise Gustav
                                                    The page that I linked includes two excellent photos [4 & 5] of the clever device
                                                    "To allow gears with numbers of teeth equal to prime numbers to be cut, a useful addition is a differential gear built, very cleverly, into one of the gears in the index train"
                                                    This looks very neat … Surely someone will remember, if they have seen its manufacture described.
                                                    Bazyle
                                                      @bazyle
                                                      Thanks Michael I was completely unaware of that page and it is really interesting and by far the best quality photos of the Jacobs on the internet.
                                                      How it works:
                                                      Normally the pulley drives the tiny spur gear that drives the very big gear that is locked to the shaft the hob is on ('hob shaft'  ) . Then the drive goes off through gears to the cardan shaft.
                                                      In the modification the 'very big gear' and the next gear in the train are on a sleeve free to rotate on the hob shaft but still transfer drive up the chain of gears to the cardan shaft. The sleeve extends and has at its end a gear that is the input to one side of the differential.
                                                      Up at the cardan shaft there is another gear train binging drive back down ending in the brass ring gear on the differential which forms the second input to the differential adding function.
                                                      The hob shaft is extended right through the sleeve and centre of the differential to drive the gear on the other side of the differential.
                                                      You can count the gear teeth and it looks like the differential is either 24/48 or 25/50. There might be some advantage in the maths for the gear trains one way or the other. The rest is pretty obvious from the pictures.
                                                      It would be nice to know who designed the modifications if not Tom Jacobs to give credit where it is due.
                                                      The maths is going to be fun. wink
                                                      Edited By Bazyle on 23/02/2016 13:46:23
