Gear design
Gear design
  • #726508
    John Haine
      @johnhaine32865
      A friend pointed me to this fascinating video which is well worth watching.
      https://www.youtube.com/watch?v=eG-z-791_ak
      Brian Wood
        @brianwood45127
        Quite right, rather clever
        #726647
        Martin Connelly
          @martinconnelly55370
          There are losses in gearboxes that show up as heat and noise, they are not 100% efficient and this shows some of the reasons for those losses. If you are driving a 10MW alternator through a gearbox then even a small percentage of that power will cause a lot of gearbox heat that has got to be catered for. These large gearboxes also induce harmonics that have to be fully understood when they are being designed. You don’t want to hit a harmonic as you are winding up the mass of a 10MW alternator, either of the prime mover or the alternator. I suspect the noise from gearboxes contributes to the hum from wind turbines, they are big gearboxes, I had to do the lifting plan for one once.
          Martin C
          #726681
          noel shelley
            @noelshelley55608
            Thanks, interesting, but by halfway the maths had got the better of me ! Noel.
            #794330
            jacques maurel
              @jacquesmaurel42310
              Hello
              Have a look at this:
              Video about the “spur gears design” including shifted profile ones:
              And some help from a free software:
              Tutorial video about the “filengrène” software:
              Best watching
              JM
