gear cutting with the shaper
Home Forums Workshop Techniques gear cutting with the shaper
  • #790675
    jacques maurel
      @jacquesmaurel42310
      Hello
      This video is about gear cutting true involute gears with the shaper being used as a single tooth “rack type” gear cutting machine:
      Best watching
      JM
        Very informative, Jaques
        Nicely presented … Thank you.
        noel shelley
          @noelshelley55608
          There are numerous videos on the use of a shaper for gear cutting on the tube and with a few clever though simple bits can cut true form gears. The shaper is a much under rated machine tool, that often come up for sale and don’t cost that much. Thanks for raising this Jaques. Noel.
          #790758
          duncan webster 1
            @duncanwebster1
            I’m now waiting for a CNC whizz to come up with a solution. Joe Noci has a CNC shaper, so couple that to a robust CNC dividing head and we’re off.
            On a more serious note, this is similar to the Sunderland gear planer, which was noted for making high quality gears.
